Door hinge post repair.
Too many pin holes. Replaced with a fairly decent replacement. Not a bad fit for non OEM. http://forums.pelicanparts.com/uploa...1520938297.jpg http://forums.pelicanparts.com/uploa...1520938297.jpg http://forums.pelicanparts.com/uploa...1520938297.jpg http://forums.pelicanparts.com/uploa...1520938297.jpg http://forums.pelicanparts.com/uploa...1520938297.jpg |
Final welds and seam sealer for the front.
http://forums.pelicanparts.com/uploa...1520938372.jpg http://forums.pelicanparts.com/uploa...1520938372.jpg http://forums.pelicanparts.com/uploa...1520938372.jpg http://forums.pelicanparts.com/uploa...1520938372.jpg Some fabrication to take the Carrera oil lines. And an semi successful attempt to straighten some of the dings. http://forums.pelicanparts.com/uploa...1520938577.jpg http://forums.pelicanparts.com/uploa...1520938577.jpg http://forums.pelicanparts.com/uploa...1520938577.jpg http://forums.pelicanparts.com/uploa...1520938577.jpg http://forums.pelicanparts.com/uploa...1520938577.jpg http://forums.pelicanparts.com/uploa...1520938577.jpg |
A few last jobs before interior paint:
grind off all the rotten carpet buttons, mounting points and fix two holes in the seat pan. Not pretty but strong. http://forums.pelicanparts.com/uploa...1520939276.jpg http://forums.pelicanparts.com/uploa...1520939276.jpg http://forums.pelicanparts.com/uploa...1520939276.jpg http://forums.pelicanparts.com/uploa...1520939276.jpg http://forums.pelicanparts.com/uploa...1520939276.jpg http://forums.pelicanparts.com/uploa...1520939276.jpg http://forums.pelicanparts.com/uploa...1520939276.jpg http://forums.pelicanparts.com/uploa...1520939276.jpg |
Mask and ready for paint.
A coat of satin black for the dash (planning on not having a dashboard) Sad to cover up this piece of the car's identity, but at least it means there is something for the next caretaker to discover. http://forums.pelicanparts.com/uploa...1520939758.jpg http://forums.pelicanparts.com/uploa...1520939758.jpg http://forums.pelicanparts.com/uploa...1520939758.jpg http://forums.pelicanparts.com/uploa...1520939758.jpg http://forums.pelicanparts.com/uploa...1520939365.jpg http://forums.pelicanparts.com/uploa...1520939365.jpg http://forums.pelicanparts.com/uploa...1520939365.jpg http://forums.pelicanparts.com/uploa...1520939365.jpg http://forums.pelicanparts.com/uploa...1520939365.jpg |
Been looking forward to these updates for a long time Matthew!
First coat, seam sealer and a good sand.
http://forums.pelicanparts.com/uploa...1520940519.jpg http://forums.pelicanparts.com/uploa...1520940315.jpg http://forums.pelicanparts.com/uploa...1520940315.jpg http://forums.pelicanparts.com/uploa...1520940315.jpg http://forums.pelicanparts.com/uploa...1520940315.jpg http://forums.pelicanparts.com/uploa...1520940315.jpg |
Final coat.
http://forums.pelicanparts.com/uploa...1520940572.jpg http://forums.pelicanparts.com/uploa...1520940572.jpg http://forums.pelicanparts.com/uploa...1520940572.jpg Looks pretty good with some of the bits I have collected. Still, a long way from bolting them in. Back to the exterior. Some work required to get my flare repair. Apply. Sand. Reapply. Sand. Rereapply Sand. http://forums.pelicanparts.com/uploa...1520940704.jpg http://forums.pelicanparts.com/uploa...1520940704.jpg http://forums.pelicanparts.com/uploa...1520940704.jpg http://forums.pelicanparts.com/uploa...1520940704.jpg And then take most of it off and get to work with a dolly and a body hammer! |
Another quick repair before the stenotype went on
http://forums.pelicanparts.com/uploa...1520941296.jpg http://forums.pelicanparts.com/uploa...1520941296.jpg http://forums.pelicanparts.com/uploa...1520941296.jpg http://forums.pelicanparts.com/uploa...1520941296.jpg http://forums.pelicanparts.com/uploa...1520941296.jpg http://forums.pelicanparts.com/uploa...1520941296.jpg http://forums.pelicanparts.com/uploa...1520941296.jpg http://forums.pelicanparts.com/uploa...1520941296.jpg |
A bit out of sequence, but the underside got seam sealer before the undercoat.
http://forums.pelicanparts.com/uploa...1520941603.jpg http://forums.pelicanparts.com/uploa...1520941603.jpg http://forums.pelicanparts.com/uploa...1520941603.jpg http://forums.pelicanparts.com/uploa...1520941603.jpg http://forums.pelicanparts.com/uploa...1520941603.jpg http://forums.pelicanparts.com/uploa...1520941603.jpg http://forums.pelicanparts.com/uploa...1520941603.jpg |
Final stone chip.
Glad to be done with the stuff. http://forums.pelicanparts.com/uploa...1520941713.jpg http://forums.pelicanparts.com/uploa...1520941713.jpg http://forums.pelicanparts.com/uploa...1520941713.jpg |
A bit of a tangent.
Started playing with the doors and custom door cards. In order to rectify some enthusiastic but badly executed repairs I needed to get better access to the outside door skin. http://forums.pelicanparts.com/uploa...1520941780.jpg http://forums.pelicanparts.com/uploa...1520941780.jpg http://forums.pelicanparts.com/uploa...1520941780.jpg http://forums.pelicanparts.com/uploa...1520941780.jpg http://forums.pelicanparts.com/uploa...1520941780.jpg http://forums.pelicanparts.com/uploa...1520941780.jpg http://forums.pelicanparts.com/uploa...1520941780.jpg http://forums.pelicanparts.com/uploa...1520941780.jpg http://forums.pelicanparts.com/uploa...1520941780.jpg |
Once I had done this there was no turning back.
http://forums.pelicanparts.com/uploa...1520942012.jpg http://forums.pelicanparts.com/uploa...1520942012.jpg http://forums.pelicanparts.com/uploa...1520942012.jpg http://forums.pelicanparts.com/uploa...1520942012.jpg http://forums.pelicanparts.com/uploa...1520942012.jpg http://forums.pelicanparts.com/uploa...1520942012.jpg http://forums.pelicanparts.com/uploa...1520942012.jpg http://forums.pelicanparts.com/uploa...1520942012.jpg http://forums.pelicanparts.com/uploa...1520942012.jpg http://forums.pelicanparts.com/uploa...1520942012.jpg |
This was the first prototype.
A proof of concept. The final versions will be done in ALU. I was avoiding more this.... http://forums.pelicanparts.com/uploa...1520942193.jpg http://forums.pelicanparts.com/uploa...1520942193.jpg http://forums.pelicanparts.com/uploa...1520942193.jpg http://forums.pelicanparts.com/uploa...1520942193.jpg http://forums.pelicanparts.com/uploa...1520942193.jpg But the doors are reasonably straight now. With less filler than I thought I would need. |
This slowed progress somewhat.
Lucky to get away with only 15 stitches. Beware a fresh flap disk... http://forums.pelicanparts.com/uploa...1520942347.jpg |
Back to fibreglass.
The hood needed some work. http://forums.pelicanparts.com/uploa...1520942836.jpg http://forums.pelicanparts.com/uploa...1520942836.jpg http://forums.pelicanparts.com/uploa...1520942836.jpg http://forums.pelicanparts.com/uploa...1520942836.jpg http://forums.pelicanparts.com/uploa...1520942836.jpg http://forums.pelicanparts.com/uploa...1520942836.jpg http://forums.pelicanparts.com/uploa...1520942836.jpg http://forums.pelicanparts.com/uploa...1520942836.jpg |
of ****!! get well soon!!
great build so far. much respect for THIS mega effort! Cheers! |
And more fibreglass.
http://forums.pelicanparts.com/uploa...1520943219.jpg http://forums.pelicanparts.com/uploa...1520943219.jpg http://forums.pelicanparts.com/uploa...1520943219.jpg http://forums.pelicanparts.com/uploa...1520943219.jpg http://forums.pelicanparts.com/uploa...1520943219.jpg http://forums.pelicanparts.com/uploa...1520943219.jpg http://forums.pelicanparts.com/uploa...1520943219.jpg http://forums.pelicanparts.com/uploa...1520943219.jpg http://forums.pelicanparts.com/uploa...1520943219.jpg http://forums.pelicanparts.com/uploa...1520943219.jpg |
| All times are GMT -8. The time now is 02:40 AM. |
