Almost a year since I last updated the thread.
(insert suitable 'time flies' analogy)
Thankfully the build has progressed, albeit not as much as I would like.
Will attempt to fill in the blanks.
Old 06-23-2014, 03:49 AM
Sills have been patched in the past.
It seems the rust was left behind!
Old 06-23-2014, 04:05 AM
Into the garage finally.
Started stripping the suspension
Roof filled with spare bits. "Better to have it and not need it, rather than need it and not have it.."
Old 06-23-2014, 04:34 AM
Part of the stash we found was a rather sorry LHD 70 Targa.
We decided to donate it's remaining organs to the resto of my mate's 0001 66 S Proto and my humble lawn ornament.
Floor pan (nice saving once stripped of the b@$%^%d underseal)
Old 06-23-2014, 04:41 AM
Traded the tired 2.7 (Kjet) that was in the car for 2 gearboxes: a 4 speed and a 5 speed 901.
Engine looks tired cosmetically but complete. It turns and the MFI pump seems to be okay. Will only really know when we get it onto a jig and try and run it. 2.2E with all standard internals (as far as I know). Plan is to run it as is, hopefully won't have to open it up to get it going. May add an alu clutch plate / flywheel for a bit more zing, but otherwise standard spec would should give 155-odd horsepower.
MFI pump is correct for a 2.2E and seems to be unmolested.
Old 06-23-2014, 05:00 AM
Visited a local specialist to do some parts swapping.
The mechanical mind behind the Dutchman Cars, Tim Abbot.
This is the Dutchman Racer in build.
Great colour.
Old 06-23-2014, 05:07 AM
After 9 months at the Panelbeaters (the most useless bunch of idiots in the World) I got my SC back. The wife is not impressed about the fact that her garage is filled with 2 porkers.
Old 06-23-2014, 05:16 AM
A few more pics of The Dutchman Racer with the interior done.
Old 06-23-2014, 05:20 AM
Finally got the car into the jig and sent it off to the sand blaster.
Couldn't face the thought of stripping the underside by hand.
Old 06-23-2014, 08:02 AM
Lovely rough, clean metal for the epoxy primer to bond to.....and lots of nasty repairs
Door lock post to sill:
Bottom of the door hinge post:
Inside the sill cavity. Inner sills look pretty solid but they'll come out when I'm in there.
Below the torsion bar tube:
Suspension pan:
Lots of rot to cut out but to be honest I thought it would be worse, so not too stressed.
Old 06-23-2014, 08:08 AM
Went for a spin in one of these.
What a car. Docile and gentle....until you put your foot down.
That motor is utterly addictive.
Old 06-24-2014, 12:42 AM
Started cutting away the rotten suspension pan and fuel tank carrier.
I spent a few hours drilling out the spot weld on the fuel tank support and then decided to cut out the whole thing and grind away what was left of the seams.
Old 06-24-2014, 01:12 AM
I hope I can save the front panel ($600 odd from RD) and patch along the sides and along the bottom. Here is my attempt at creating a patch template.
A sort of rally patch....
Old 06-24-2014, 01:25 AM
Bear911's Avatar
Wow, there is a lot of work there! I'm 50% jealous and 50% relieved that it is not me, haha!
The patch idea looks good. While you are at it, you can also work in a bit of a recess for an RSR style oil cooler... mmmmm...
Old 06-24-2014, 09:08 AM
Bear911's Avatar
Kinda what I'm getting at....
Elephant Oil Cooler Duct Install
I know the vision a 911R of sorts, but this could still be a nice touch.
Old 06-24-2014, 09:22 AM
Bland
unclebilly's Avatar
What does that 2.2 E engine have a green shroud? The green shroud is a midyear 911S item. It should be black on a 2.2E engine.
Don't get me wrong, the green shroud has better air flow but would cause me to look a bit deeper into what this engine actually is.
Old 06-24-2014, 12:53 PM
Thanks Bear911.
To be honest doesn't feel like I've done that much when I see the car in the garage every day. New steel welded in and everything in primer will be a major milestone.
Can't wait for it to be all in primer. Sanding primer gives a sense of progress.....strange considering that after years on shiny boats I can't bare bloody sanding!
Chin cooler mod is interesting. Would solve my missing metal problem.
But it necessitates an rs front bumper?
I have a 's' front bumper. Will run an oil cooler in the wing.
I think the rs/r front bumper with oil cooler works on the hips of an rs/rsr.
Last week's plan was to keep the skinny hips of this one......but do have a set of original steel carrera flares.
Old 06-24-2014, 01:25 PM
Max Sluiter
Flieger's Avatar
Green is correct for an early E. T was yellow, E was green, S was red. 73.5 was black over yellow gell coat.
Old 06-24-2014, 06:22 PM
It's a 2.2E.
As Flieger correctly details.
At numbers / part numbers are correct.
The internals may have been changed, the mfi pump recam'd, but I doubt it.
155/160hp in a light car should be more than enough for me.
Old 06-25-2014, 12:28 AM
Started spraying suspension parts. 2K primer, then satin black.
Good parts to practise my spraying
SWB trailing arms....rare little buggers.
Old 06-26-2014, 12:40 AM
