rfuerst911sc's Avatar
how are you protecting lug nuts during installation ?
OK I have freshly painted 911 aluminum lug nuts how do you protect them during installation ? Soft socket ? Socket inserts ? Homemade solution ? Help please.
Old 05-16-2013, 04:44 PM
Bill Verburg's Avatar
I use a soft socket where the wheels have room, otherwise a 6 pt socket and hand tighten/loosen(no torque wrenches
Bill Verburg
Old 05-16-2013, 04:47 PM
Mo money = mo parts
I use a plastic grocery bag. Loosely cover the lug with a double layer of the bag, and you should still be able to slide the socket over the lug. You need to constantly move the bag around because the bag gets destroyed after one or two nuts. Also, the paint will still wear off eventually, this buys you a little extra time. A six point socket will also help.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 05-16-2013, 05:39 PM
I use sandwich type bag,(or a zip lock) about one bag per wheel. Makes a nice tight fit and no marks on lug nuts. I put the bag over the socket so it doesn't wind up.
Old 05-16-2013, 06:23 PM
Eva
911SauCy's Avatar
I did a brushed finish on mine
No more worries.
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 05-16-2013, 07:03 PM
skinnerd's Avatar
Ditch those "girly man" fragile aluminum lug nuts for some simple open ended steel ones, and you'll never have to worry ever again.
Added bonus....you get the "racer" look.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 05-16-2013, 07:12 PM
Cooper911SC's Avatar
Plastic bag or wax paper as others have said.
If you are showing the car that's a whole different ball game.
Concours with regional PCA is "Creating the illusion of perfection"
I strip and repaint lugs before each Concours event during a season. Yes that means 5-8 repaints...
The best solution is to have a fresh set of anodized lugs for show and another set for street use.
If you are gentle with the new anodize it will hold up very well.
Cooper
Old 05-16-2013, 09:34 PM
Andrew Gawers' Dad
CHICKS's Avatar
You dont use a torque wrench, and only hand tighten your lugs?
I assume you meant impacts, just giving you greif.
Old 05-16-2013, 10:13 PM
Old 05-16-2013, 10:57 PM
Almost Banned Once
sc_rufctr's Avatar
That's what I did... No going back.
- Peter
Old 05-16-2013, 11:38 PM
Hellraiser's Avatar
Send a message via MSN to Hellraiser
Did the same thing to all my porsches, how many splintered aluminum/magnesium lug nuts do you want?
Old 05-17-2013, 12:14 AM
Eva
911SauCy's Avatar
That's the next step
Old 05-17-2013, 05:26 AM
I do have a set of open metal lug nuts but for the street I really want the aluminum ones.
Old 05-17-2013, 01:48 PM
Taking it apart is easy
Jerome74911S's Avatar
Another vote for a plastic bag, or cling wrap on the nut, so that the six-point socket is 'lubricated' by the plastic and also cushions the pressure from the socket while tightening the nut.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 05-17-2013, 03:15 PM
závodník 'X'
intakexhaust's Avatar
I have a deepwell socket made by SnapOn. The insert is a hard plastic or resin. Usually they sell them in a set but I was able to acquire a single socket from a dealer.
BTW: The nuts are NOT aluminum but actually magnesium.
Old 05-17-2013, 06:28 PM
1984 Porsche Carrera
ozracer's Avatar
shopping bag works great not the thin ones you can almost see through the thicker waxy styles work great and I can usually do a full wheel without any tears
Old 05-17-2013, 10:07 PM
ditch those "girly man" fragile aluminum lug nuts for some simple open ended steel ones, and you'll never have to worry ever again.
+1
Sold: 1989 3.2 coupe, 112k miles
Old 05-18-2013, 06:35 AM
I use blue painter's tape on the inside and outside of the socket to prevent scratching the nuts and wheel. Might need a 1mm bigger socket if you really line the inside thoroughly. This is the only thing I use that socket for, so the tape stays on (makes it really easy to find, too).
Old 05-18-2013, 11:13 AM
HarryD's Avatar
OMG!!!!!! Now I will lie awake nights wondering how badly I screwed up my lug nuts over the past 10 years of just using a standard impact socket to loosen and tighten my nuts (using a torque wrench for the final setting, of corse).
The horror!!!!!!
Old 05-18-2013, 04:35 PM
