how are you protecting lug nuts during installation ?
OK I have freshly painted 911 aluminum lug nuts how do you protect them during installation ? Soft socket ? Socket inserts ? Homemade solution ? Help please.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
I use a soft socket where the wheels have room, otherwise a 6 pt socket and hand tighten/loosen(no torque wrenches
Mo money = mo parts
I use a plastic grocery bag. Loosely cover the lug with a double layer of the bag, and you should still be able to slide the socket over the lug. You need to constantly move the bag around because the bag gets destroyed after one or two nuts. Also, the paint will still wear off eventually, this buys you a little extra time. A six point socket will also help.
Greg 86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten 65 Ducati Monza 250 & 66 Monza Junior (project) "if you are lucky enough to own a Porsche, you are lucky enough" |
Eva
I did a brushed finish on mine
![]() No more worries.
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
Ditch those "girly man" fragile aluminum lug nuts for some simple open ended steel ones, and you'll never have to worry ever again.
Added bonus....you get the "racer" look.
"Are you out of your Vulcan mind?" Doug 2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS |
Plastic bag or wax paper as others have said.
If you are showing the car that's a whole different ball game. Concours with regional PCA is "Creating the illusion of perfection" I strip and repaint lugs before each Concours event during a season. Yes that means 5-8 repaints... The best solution is to have a fresh set of anodized lugs for show and another set for street use. If you are gentle with the new anodize it will hold up very well. Cooper |
Andrew Gawers' Dad
Almost Banned Once
- Peter |
Eva
I do have a set of open metal lug nuts but for the street I really want the aluminum ones.
Taking it apart is easy
Another vote for a plastic bag, or cling wrap on the nut, so that the six-point socket is 'lubricated' by the plastic and also cushions the pressure from the socket while tightening the nut.
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
závodník 'X'
I have a deepwell socket made by SnapOn. The insert is a hard plastic or resin. Usually they sell them in a set but I was able to acquire a single socket from a dealer.
BTW: The nuts are NOT aluminum but actually magnesium.
“When these fine people came to me with an offer to make four movies for them, I immediately said ‘yes’ for one reason and one reason only… Netflix rhymes with ‘wet chicks,'” Sandler said in a prepared statement. “Let the streaming begin!” - Adam Sandler |
1984 Porsche Carrera
shopping bag works great not the thin ones you can almost see through the thicker waxy styles work great and I can usually do a full wheel without any tears
+1
Sold: 1989 3.2 coupe, 112k miles |
I use blue painter's tape on the inside and outside of the socket to prevent scratching the nuts and wheel. Might need a 1mm bigger socket if you really line the inside thoroughly. This is the only thing I use that socket for, so the tape stays on (makes it really easy to find, too).
OMG!!!!!! Now I will lie awake nights wondering how badly I screwed up my lug nuts over the past 10 years of just using a standard impact socket to loosen and tighten my nuts (using a torque wrench for the final setting, of corse).
The horror!!!!!! |
