Battery vent hose routing.
I'm told it's an easy thing. I can't find a hole that routes out to the bottom of my 84'.
Member 911 Anonymous
There is none, just leave it off or let it just hang downward
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
I drilled a hole in the body side....
grab an agm battery and never worry about a vent hose again.
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
I also drilled a hole, put a grommet, then ran a hose as far as the bottom of the windshield washer tank, far from any body sheet metal. I was a bit of a pain ....I dropped the washer tank to gain access. Those battery vents will let acid and fumes out, over time will cause damage. Of course for $$$ you can buy an Optima.
there are lots of agm batteries out there, not just optimas. this is the one i have used for the last few years with no problems at all, including leaving the door open one night and draining it. it's $80 shipped. Kinetik 600 Watt 12V Power Cell KHC600 - Newegg.com
if you used to have a/c and now have a metal panel filling the hole where the blower was, that's a good place to drill a hole to run the vent hose. that's what I did.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
