toddu's Avatar
Removing "shift fork plate"
While my motor is out (and in the good hands of Mike Bruns), I'm taking the opportunity to clean up the tranny and replace some seals/gaskets. I seem to have some weeping on some of the studs for the shift fork plate on the bottom of the tranny. I'm assuming the gasket/seal kit I purchased from PP will have this gasket in it.
The only thing I can find about removing this plate is in rebuild threads. In Zimmermans rebuild wiki, it's one of the last things that gets installed back on the tranny. It looks like it somehow interacts with some internal bits, so I have a bit of reservations about removing it.
If nothing is coming out of the tranny, am I ok to remove this plate and should have no issues getting back on?
Todd
'81 SC
Old 05-24-2013, 08:23 AM
I had mine out to stop a leak, no surprises. Have a container to catch gear oil that will continue to drip out of the transmission.
-Wade
1972 Targa, nothing matching.
Looking for motor 6124265 and transmission 7720299
Old 05-24-2013, 08:35 AM
pete3799's Avatar
Remove it......the guide fork might be loose. Was on mine. All three bolts ( studs) were loose.
Worth a look just for the peace of mind.
Pete
79 911SC RoW
Old 05-24-2013, 09:10 AM
E Sully's Avatar
The first time I installed the plate I had a little seepage. I replaced the gasket the second time with a very thin coat of Locktite 574 and no drip. Check to make sure the fork is snug on the plate. I have read a couple of threads where it had loosened up and caused shifting problems.
Ed
1973.5 T
Old 05-24-2013, 09:11 AM
Peter Zimmermann's Avatar
If the trans is in neutral when you re-install the plate you won't have any difficulty putting it back on. If you use the gasket use a thin coat of Curil T on each side.
As already mentioned, check the nuts on the fork plate to make sure they're tight. The fork is fixed in place, so when you install the plate just watch the fork, it's easy to see how it fits.
Keep the Shiny Side UP!
Pete Z.
Old 05-24-2013, 09:46 AM
toddu's Avatar
Sounds good guys!!! It's coming off then. I've got the transmission on an engine stand, so everything is very accessible.
Todd
'81 SC
Old 05-24-2013, 10:06 AM
One more thing; when you clean your gasket surfaces, don't use oil-based solvents. Lacquer thinner or MEK work the best.
Pete Z.
Old 05-24-2013, 01:06 PM
Grand Am/IMSA Data Guy
Porsche84's Avatar
Todd
If you are only pulling the bottom plate, I can send you a new gasket so you do not need to buy a gasket set, ..... free.... PM your mailing address
Jerry Austin
AIM Data Products Dealer
84 911 3.6 track car - Sold
Morris Minor Van with S2000 running gear
http://austinmotorsportsllc.com/
Old 05-25-2013, 08:20 AM
