donnie (guest)
Guest
Posts: n/a
door stay that i replaced works in 2 positions,but it clicks when i move door to open?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Door Stay Replacement and Reinforcement - 911 (1965-89) - 930 Turbo (1975-89)
Old 05-28-2013, 03:54 PM
Nick at Pelican Parts's Avatar
Check to see if the door metal that supports the stay is not bent. It may be hitting because the whole panel is bent
- Nick
76 911S Targa
"There are multiple threads on this. The John Walker fix is to use a 6mm bolt and nyloc nut in place of the press fit pin. Tighten just enough to prevent unwanted movement. No more pop. "
Question on "snapping" sound in driver's door
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 05-28-2013, 04:21 PM
