Did 1969/912 all have front sway bars?
I have a very low mileage 69/912. Someone started installation of after market front sway bar. I am removing it. But did the 69/912 even have a factory front bar. I would prefer to leave it off if that is possible correct?
Stephen
Old 05-29-2013, 12:29 PM
69 would have the through the body sway bar with drop links. Look on the A arm inboard of the ball joint on top. If you find a U shaped bracket with holes then the car had factory front sway bar. There would also be a triangular plate with 3 bolts holding it to the inside wheel well. Sway bar passes through this plate and rubber bushing. If none of this is present your car didn't have the bar. I think it was an option on the 912 and I think also on the 911T. I had a 66 912 when I was in the Navy in Spain in the late 60's. No speed limits. I drove the wheels off that poor car. I wish I still had it. They are fun cars. Enjoy.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 05-29-2013, 01:54 PM
The sway bar was an option but the A-arm fitting was provided for in the 69, even if it wasn't delivered with the sway bar option.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 05-29-2013, 01:59 PM
Perfect, I will remove after market and put it to stock. Non option sway bar.
By the way it is OSSI BLUE! Great color, 22,700 miles
Thanks,
Stephen Retrotech: Classic and vintage Porsche cars, accessories and Porsche parts
Old 05-29-2013, 02:05 PM
gearhead
Like ossiblue said by '69 it was an option even though all a-arms had the u-tabs.
Earlier it was standard equipment, like on my '67. I think '68 was the last year it was standard but would need to look it up.
I would be interested in the bar once you remove it. Also, only a COA would tell you if your car was optioned with one. If it was, and you would like to install a stock factory one, I have one that I would offer as partial trade towards the purchase of your aftermarket one.
Old 05-29-2013, 03:28 PM
I won't being doing a COA, But I could be interested in trade+ if you have every little bushing, spacer, nut & bolt from original. E mail me at retro356@gorge.net
Old 05-29-2013, 03:31 PM
SCadaddle's Avatar
69 912 front sway bar.
Old 05-29-2013, 09:00 PM
Home of the Whopper
WOW!! What a beautiful car! Love that color.
The wheel pads are so the floor doesnt get the tires dirty?
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 05-30-2013, 04:57 AM
Ayo Irpin, Ukraine!
70SATMan's Avatar
The 912 if optioned with a front sway was likely the 13mm not the 15mm.
That is if I recall correctly..
Harmlessly passing gas in the grassland away;
Only dimly aware of a certain smell in the air
Old 05-30-2013, 08:16 AM
gearhead
I'm on the road for the next few days including the weekend. I will inspect all my parts when I return and drop you an email at that time. This is one that is already off the car, and not the one in place on my '67.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 05-30-2013, 09:35 AM
