The 901 is a dog leg box. Where is first gear fwd or down and back?
75 911s 86 951 sold to make room for baby seat 09 335i 6MT NVH |
AAEEEEE!
Forward left = G50
Steve Laissez les bons temps rouler |
Nice car .. looks like a tuxedo ...
usually not a fan of the white interior but yours pulls it off ... Have fun ... they are addictive though .. I started with one and now have two 911's and a 914 ... |
Looks great! I like the component setup in the front doors.
If you had a 901 tranny you would have put in about one quart less trans oil than you did.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
that oil incident sounds pretty funny, benny hill theme playing in the background. kind of a dumb pan design. i like the kind that have a wide opening with a screen to catch the drain plug/washer. i don't think you lost all 12 quarts; you should've only lost 5-6 quarts as around 2-3 quarts are stuck in the oil lines/cooler and don't come out and the rest is split between the oil tank and sump. unless you did it twice...
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
AAEEEEE!
![]() ![]() On our way outta Baton Rouge Went to work as soon as we got home, found out the washer pump wasnt working because it has a crack in housing
Steve Laissez les bons temps rouler Last edited by sacoffee; 06-01-2013 at 09:21 PM.. |
AAEEEEE!
![]() Working on the stains with degreaser
1988 Carrera
Try using kitty litter, the cheap kind. Grind it in with your foot. Works for me.
MBruns for President
And tide laundry detergent. Congrats. And BTW it's not really yours until you have bled on it
Platinum Member
I doubt it's a trans swap. 1988 had g50 with hydraulic clutch, and different cv joints. It would be a ridiculously stupid conversion.
Shift sloppy? check the joints under the shifter, and towards the back. |
Oil spill
My kids called it an Exxon Valdez.
I think we've all had one. What only one? |
Member 911 Anonymous
Congrats! Beautiful Cab and Welcome to the Oil Leak world of the 911
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Thanks for the pic of the oil leak ..
Also I see that adding your location worked ... the cars and coffee out here are pretty good ... Our new years day runs get close to 100 out of bed at 8 am ... and the anti football turkey sandwich friday drives have been epic in the past .... |
Not exclusively.
The 915 is also forward left for first. The 915 was used between the 901 and G50 from 72 to 86. G50 was stock for 87-88-89. So, if the original trans is in the car, that's what you have. The 901 and 915 are Porsche trannys. The G50 is a Borg-Warner. It's heavier. Last edited by tcar; 06-02-2013 at 05:46 PM.. |
Almost Banned Once
- Peter |
Also,
Pics help. You have an M-491 (turbo-look) option. (Unless the body has been diddled with.) If so, the car is basically a 930 turbo except for the engine. Should have turbo brakes, suspension, etc. Check the VIN to be sure. Would look better with the stock Fuchs, IMO. |
If your car is a 1988, your car has a G50 tranny for sure. If not, I would call back the previous owner...
1985 911 Targa (sold) 2001 996 Twin Turbo (sold) 2001 996 C4 Last edited by Nico911; 06-02-2013 at 05:19 PM.. |
AAEEEEE!
AAEEEEE!
