p7guru's Avatar
Emergency! 3.6 converted careers won't turn over in boonies!
Hey, I just drove my new to me 88 carerra with 95 3.6 conversion from Philly to NC. I stopped to pee and it won't start! If you turn key lights come on but no turnover--not even a bit.
Any emergency tips? I am stuck and 7 hours from home!
Old 06-01-2013, 07:39 PM
wwest's Avatar
Stick shift...Push to start
Old 06-01-2013, 07:41 PM
Northern Motorhead
wildcat077's Avatar
How's the battery ?
Check to see if the alternator belt is tight ... i guess without a voltmeter and basic tools there's not too much you can do.Perhaps try to get a push start and see if that works ...
I'm sure someone else will chime in with helpful advice !
Cheers
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 06-01-2013, 07:45 PM
non-whiner
mreid's Avatar
Neutral safety switch? Clutch safety switch?
"Too much is just enough."
Old 06-01-2013, 07:51 PM
RETIRED
Joe Bob's Avatar
Whack the solenoid with a BFH......call the previous owner and ask WTF?
Check battery connections.....long drive w/o AAA?
EDIT: Yes hot start.....if you wait an hour it maight start.....whacking the solenoid frees it up.....
2012 ML350 3.0 Turbo Diesel
Old 06-01-2013, 07:55 PM
OsoMoore's Avatar
Could be an overheated starter solenoid. This happened to me last summer. I was able to push-start the car. Later, when it cooled off, it started fine.
That issue is known as a heat-soaked starter. Good luck and I hope you get home safe soon!
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 06-01-2013, 08:32 PM
Fuel pump relay?
Old 06-01-2013, 08:54 PM
p7guru's Avatar
Easy fix! Stupid battery cable had corroded through. Took everything apart and cleaned it. Jump started good as new.
Thanks guys!
Old 06-01-2013, 10:14 PM
RETIRED
Joe Bob's Avatar
Oi...JB pegged it....
Old 06-01-2013, 10:15 PM
