Rebuilt My Turn Signal Relay
My turn signal relay on my Targa has been intermittent -- working sometimes and not at all at other times.
These original Hella relays can be easily disassembled and inspected with a thin-bladed tool or small screwdriver. I cleaned the contacts with 1500 sandpaper, with no joy and continued intermittent operation. The circuit components all looked fine. There are, however, two 47 microfarad capacitors on the board. I bought replacements for both of those at Radio Shack for $3 and change.
Replacing the capacitors isn't a difficult task if you're confident in your soldering skills. Anyway, a few minutes of work and my original relay is flashing like it should.
Brian
'82 SC Targa
'83 SC Cabriolet
Old 06-02-2013, 10:02 AM
RETIRED
Joe Bob's Avatar
I applaud your successful repair. Most would toss and buy a new one. Good on ya.
2012 ML350 3.0 Turbo Diesel
Old 06-02-2013, 11:01 AM
ROW '78 911 Targa
timmy2's Avatar
Good job. Pictures?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 06-02-2013, 11:12 AM
I DID recently toss in for the genuine part for a hefty $107!! Wish I new about this option earlier
Old 06-02-2013, 02:04 PM
RETIRED
Joe Bob's Avatar
Oz tax? They are like 35USD....
Old 06-02-2013, 02:15 PM
pete3799's Avatar
Early SC relays are in the 60.00 range i think ( can't even find a listing for them anymore.....Wayne?). Good work on the repair.
Pete
79 911SC RoW
Old 06-02-2013, 02:19 PM
More like Porsche tax. We get fleeced pretty good down here. They charge what the market will bear.
Old 06-02-2013, 03:12 PM
My local auto parts store quoted something like $58 and it was a special order item. It was enough money and hassle to encourage me take a second look at repairing the non-working original relay.
Brian
'82 SC Targa
'83 SC Cabriolet
Old 06-03-2013, 08:10 AM
I should add that when replacing capacitors on a circuit board, always make a note of the polarity (positive and negative poles).
Brian
'82 SC Targa
'83 SC Cabriolet
Old 06-04-2013, 07:05 AM
Less brakes, more gas!
euro911sc's Avatar
How did you know it was the caps? I had to replace mine last year... but I still have the original one. Might be worth screwing with...
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 06-04-2013, 08:57 AM
I didn't. Replacing the capacitors was an informed guess. The relay coil and the resistors on the board all had continuity. Capacitors are difficult to test without specialized gear, but they do fail/become flaky over time. For $3, I guessed correctly. And I wasn't out much if the hunch was wrong.
Brian
'82 SC Targa
'83 SC Cabriolet
Old 06-04-2013, 09:15 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Side note...when replacing capacitors...check the operating voltage of the old one...replace with same capacity but higher voltage rating if you can.
Also...there are caps with bi-direction capability if you cannot determine the polarity of the old one...although a simple voltage check will tell you which side is the positive.
There is also the operating temperature to consider....a gold rating of +80C is about normal...but there are caps with +120C available.
The higher limits for the cap will extend the life expectancy.
Bob
Bob Hutson
Old 06-04-2013, 12:46 PM
T77911S's Avatar
do you think it may have just been a bad solder joint and replacing the caps just fixed the joint?
just asking because i see a lot of this problem.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 06-04-2013, 06:40 PM
dshepp806's Avatar
I you removed the ORIGINAL electrolytic caps (check the manufacture date stamp), then you surely made a very smart move,..very cheap fix. that electrolytic isn't like wine, for sure. They, eventually, need replacing. A higher voltage rated cap would be a smart move, as well.
Good work!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 06-04-2013, 09:18 PM
T77911S's Avatar
are they electrolytic or ceramic caps? the electrolytic caps WILL "dry" up and go bad.
they were a nightmare when we had an old military voice switch here back in the early 90's. i still have a drawer full of them.
electrolytic caps are generaly polarity sensitive as said. if there is a band or crimp, that is positive. there may be an arrow pointing to negative. if nothing, dont worry about it.
this is why CD units go bad and still have the whine, the large electrolytic cap goes bad.
RACE CAR:: sold
Old 06-05-2013, 04:24 AM
No, this is a small, very simple circuit board, and you can easily check it for cold joints, etc. I also went around it checking continuity. Process of elimination.
The old capacitors lasted 31 years, and the relay lives on...
Brian
'82 SC Targa
'83 SC Cabriolet
Old 06-05-2013, 07:22 AM
