need help with fuel injection on 83
I replaced the fuel lines on my 83 SC. The lines from the tunnel thru the fuel accumulator, filter to the fuel distributor.
I cannot get the car to start. I pulled an injector and I am not getting any fuel out of it.
I know I am getting fuel to the fuel distributor due to leaky connections that have since been tightened.
I remember reading somewhere in a post about bleeding the air out the system I do not know if that pertains to my CIS system or not.
any help would be greatly appreciated
gone 82 928 Comp pkg 83 911 SC RS
69 911 T lightweight canyon carver outlaw soon
Lotsa Ducati's
99 Triumph 995i track bike
www.porscheresto.com
Old 06-05-2013, 05:34 PM
Senior Advisor
James Brown's Avatar
how did you check that the injectors are not putting out any fuel?
08 Cayenne Turbo
Old 06-05-2013, 05:47 PM
fuel issue
I pulled an injector and put it in a bottle and had my son try to start the car and no fuel came out
Lotsa Ducati's
Old 06-05-2013, 06:35 PM
schumicat's Avatar
you bleed by removing air filter and with key on very briefly lifting the little arm. don't do it too long or often or you can flood the cylinders.
you can also try spraying some starter fluid (don't try this w/o a pop off valve on the air box) and see if the engine will stay running.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 06-05-2013, 06:36 PM
Ok thanks I will give that a try tomorrow to frustrated so I called it day. When it stops being fun I call it day and regroup
Lotsa Ducati's
Old 06-05-2013, 06:44 PM
Senior Advisor
yep with the ignition on, lift the air plate with one or all the injectors out in the little bottles. should purge quickly, don't flood the engine
08 Cayenne Turbo
Old 06-05-2013, 06:47 PM
CIS start-up.......
Thom,
Do you have a fuel injection pressure gauge kit? It is a mandatory tool for fuel injection troubleshooting regardless if you have Ketronic, Motronic, etc. without one, it would be an uphill battle to find the culprit/s. If I were in your shoes, these are what I would do:
1). Check the fuel pressures by running the FP. No need to start the engine at this point. Know what your control and system pressures are.
2). Check for air/vacuum leaks.
3). Check ignition sparks.
4). Have a fully charged battery.
5). Check that the 7 injectors are spraying mist-like patterns. Yes, there are 7 injectors in your CIS engine.
If the engine was running before, it should be an easy start-up. Keep us posted.
Tony
Old 06-05-2013, 08:03 PM
I have spark. I am sure it just needs to be bled since I changed nothing else
Lotsa Ducati's
Old 06-05-2013, 08:20 PM
Where can I get a pressure gauge set I could not find one on our hosts site
Lotsa Ducati's
Old 06-05-2013, 08:29 PM
ROW '78 911 Targa
timmy2's Avatar
Google cis k-Jetronic injection tester. Pelican is out of stock on their less expensive one. They do have a good one though.
Old 06-05-2013, 09:59 PM
Alright I lifted the sensor and I know have fuel to the injectors still no start I may have flooded the car
Lotsa Ducati's
Old 06-06-2013, 08:44 AM
I tried swapping in a new set of spark plugs still no luck
it just cranks without starting
if I hold the gas to the floor it will sputter but not catch
Pretty frustrating
Lotsa Ducati's
Old 06-06-2013, 10:03 AM
I am getting spark and when I pull an injector and lift the sensor plate I get a strong mist of fuel
Lotsa Ducati's
Old 06-06-2013, 10:08 AM
I am wondering if I may have damaged my ecu yesterday. I jumped the car and bumped the leads together and got a spark
I am clueless on next steps any suggestions?
Lotsa Ducati's
Old 06-06-2013, 10:22 AM
Senior Advisor
no ecu on a 83, so good spark and fuel, cranking it sputters with the throttle wide open. If all the air leaks are accounted for, i would keep cranking without flooring it. it should catch soon. Put a battey charger on it
08 Cayenne Turbo
Old 06-06-2013, 03:43 PM
Car was flooded. It only cost me 95 dollar to learn how to clear a flooded cis car
75 towing fee
20 shop fee at eisenbuds in denver
Basically hold down the sensor plate and have someone crank the car over till it starts
I have paid allot more for training and got a lot less.
I feel I got off cheap can't say enough about John at eisenbuds took my car directly off the flatbed and got it running in 10 mins you just do not get that kind of service
Lotsa Ducati's
Old 06-06-2013, 05:01 PM
T77911S's Avatar
i paid over 200 for a nutt!
changed the AC compressor on my vovlo 960 when i was out of town for a long period.
there was a hidden ground wire on a nut that i could not see but had to remove. had it towed to volvo. took him a while to find it.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 06-07-2013, 03:51 AM
