87 Carrera failed DEQ (Oregon Emissions) - suggestions?
I recently acquired a 87 Carrera with around 140k miles. The car seems to be in great shape, with good leakdown/compression numbers.
My father took it in today to get an emission check (DEQ here in Oregon) and it failed. The CO numbers were too high. The numbers on the form read: CO - 2.1141 and 2.3081 CO2 - 6.8 and 6.7 HC - 128 and 108 The car was probably sitting for about 2 months, and I have yet to change spark plugs, oil, oil filter, air filter, etc. I was planning on a nice long drive, but what else can I do to pass this test? |
Banned
If the NOx numbers are high as well, then your catalyst is shot.
Any time that the CO% is very high, you must consider an air flow meter replacement. We have seen the problem on a number of cars, so your first step is to find a good independent who has a proper CO machine and the knowledge to set the CO on the car. If the CO% will not lean out, chances are good that your AFM is faulty.
Keep the Shiny Side UP! Pete Z. |
unplug one injector. instant air pump. deal with the real problem later.
Disconnect the battery, change the oil and oil/air filters, connect the battery, put in PREMIUM fuel, the more the better, run the car hard (stay in low gears) on the freeway, A/C going WOT, arrive at the test station with the engine HOT, shut it down as much, as often as you can waiting in line at DEQ so the engine doesn't cool.
A good tune up, get the car hot, use a hi quality hi octane premium fuel (go to Chevron), go when the line is short to keep the motor hot.
If this does not work, there are several excellent shops in Portland who can help you as well. I like Kurt at Marque Motors but others can help you as well.
Thanks for the replies. I think I'll be taking it to Kurt at Marque to sort out. I don't that the time to mess with it, so it's going to hit me in the wallet instead...
Make sure that the brown wire under the driver's seat next to the DME control unit is connected. This will drop your numbers enough to pass if it's not. If your cat is bad, however, then your 911 may not pass no matter what.
Call the guys at Stuttgart Autotech in Lake Oswego, ask if they can test your cars emissions and also check if your oxygen sensor system it working.
I recommend the DEQ test station in Tualatin for shorter lines. I drove my 84' there straight from the dealer lot and miraculously passed with a cat bypass and nearly fouled plugs.
Run it over to Marque motors and let Kurt have a look.
-C
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
Yep,...thats the right place.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Porsche Owner
or get Special Interest plates now that your car is over 25 years old.
you wont ever have to worry about deq
1987 Carrera - 2008 Cayenne Turbo |
Hope you get it sorted out.
Are you aware of our monthly get togther at Pyramid? http://forums.pelicanparts.com/pacific-northwest-us-wa-id-ut-hi-ak/500446-oregon-pdx-beers-burgers-second-thursday-every-month.html All you need to do is show up and have fun.
Please post your "fix". As a future Oregonian, I'm very curious to how this turns out.
Doug Currently Between Porsches PART OF MY SOUL: '09 Boxster 2.9 PDK, '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944 |
Diss Member
Brown wire reduces the NOX emissions so won't do anything for what he is testing for.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
ROW '78 911 Targa
Depends where you are going to live, no DEQ in Salem...
![]() Quote:
Ah, the joys of old Porsche ownership...
I'm getting ready for smog in California, not Oregon. I will change the plugs but probably not anything else - not many miles on the car in the past few years. Then I'll hook up the fuel pressure gauge, and the LM-1 fuel air gauge. With the O2 sensor disconnected, I'll go for a slightly rich mixture. With the O2 sensor connected and engine warm, I open the oil cap to watch the mixture go "lean stop". It spikes lean and then in a second or so go back to .98 to 1.02 lambda. Same thing when I disconnect the fuel pressure regulator vacuum line. It goes "rich stop". This verifies the health of the O2 sensor. With the cat bolted on, it will pass.
..alas, greater PDX area..
