Removing Lambda brain harness
Have everything out except the wire running through the bulkhead by the pedals into the front fuse block.
How do you remove this wire? I can't find it on the trunk side. And where does it connect on the fuse block? Can I cut it and wire nut it? Todd
'81 SC |
Recreational Mechanic
Several of those wires run in a void between the frunk floor and gas tank. Difficult to reach without removing the tank.
Are you ditching CIS for carbs?
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
Red wire.........
Todd, The red wire from the ECU wire harness supplying power to the FV relay goes to S18 (fuse #18). Tony |
Yes, I'm moving to carbs.
Fuse 18, thanks!! I'll see if I can remove it there and go the other direction. Not going to remove the tank. Did that to install sway bar and don't feel like doing it again just to remove 1 wire. Todd
'81 SC |
Succes!!!
No please tell me my fuel pump is still going to operate :-) Not understanding the tie into the FP relay. Todd
'81 SC |
