Home brew alternative to hard line support "padding"
The hard lines along the rocker panels are held by three clips and there is padding of some sort between the clips and the brass line. I had the lines out to get at a stubborn line on the thermostat and these things just crumbled. There are a total of 8 of them and they are ~$10 each. Has anyone come up with an alternative material? $80 seems a bit much. Was thinking of getting a couple feet of thin walled heater hose from my FLAPs as one alternative.
Anyone have any other ideas?
Kinsley
1980 SC Targa - MS2, EDIS
Old 06-10-2013, 09:56 AM
I think I just cut up some bicycle inner tube for mine...
'77 S with '78 930 power and a few other things.
Old 06-10-2013, 12:46 PM
76 911S Targa
Hot water pipe wrap from the hardware store?
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 06-10-2013, 12:54 PM
BoxsterGT's Avatar
Porsche Crest
No, too soft. Inner tube will work just fine. A piece from a truck inner tube would even be better.
$10 ea,....... HA! What we spend on our wonderful cars.
Len
Old 06-19-2013, 11:43 AM
I ended up getting 2' of 3/4" id heater hose from a FLAPS for $1.10. Suspect it will outlive the car. Better padding than OEM version as well.
Of course I'll never win a concours now
Kinsley
Old 06-19-2013, 02:45 PM
schumicat's Avatar
I was able to get several OEM ones on ebay for a reasonable price (around $10 for 8 of them). you can find insulated cable clamps at lowes cheap and the rubber is pretty much the same.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 06-19-2013, 03:21 PM
French Import
zippy_gg's Avatar
I bought about a foot of black rubber hose for under $2.00 from Home Depot, enough for 8 pieces.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 06-19-2013, 03:26 PM
