Caveman Hammer Mechanic
ClickClickBoom's Avatar
Get rid of the stupid green shielded wire, nothing but trouble.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 01-08-2014, 07:58 PM
I don't remember if I mentioned it earlier in this thread, but we ended up doing that.
Old 01-08-2014, 08:05 PM
ROW '78 911 Targa
timmy2's Avatar
Did you replace it after your post about repairing it? Or did you run new wires?
Old 01-08-2014, 10:21 PM
toddu's Avatar
Did you figure this out? My 6AL is solid for a few seconds, blinks, then shuts off with key in start. Can't start the car yet (no oil tank), just confirming electronics at this point.
I also don't get rev limit verification (tach sweep when turning key on). I haven't begun to troubleshoot anything however.
Todd
'81 SC
Old 02-01-2014, 06:02 PM
Not figured out yet. I have a local enthusiast coming to help me out tomorrow morning. Hopefully we'll get it. I have done some diagnostics and think the MSD unit has gone bad.
Old 02-08-2014, 10:40 PM
Just to update, this time the issue was the coil. My new best friend brought over a good one and after going through all of the diagnostic checks from the MSD write-up we connected the new one. Whammo- spark!
I'll be on the phone with MSD tomorrow to get my coil replaced under the 1 year warranty.
Big, huge thanks to Bruce G. for coming over to my place today. He was a huge help and it's great to know such a knowledgeable guy so close to me.
Old 02-09-2014, 10:40 AM
Good for you! glad you solved it with help. I had the same thing happen on my Speedster years ago. Seems like the coil is the last thing you suspect and they are not easily tested, but replacing it with a good one is usually the way to troubleshoot.
Most round MSD coils are made in China. They should replace it for you. I would put in a good transformer type coil. They are bigger, but work well with CDI. I had one on my stock Bosch and it was a big improvement over the Bosch coil.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 02-09-2014, 12:58 PM
What do you mean by transformer type coil?
Old 02-09-2014, 01:04 PM
This is what a E core transformer type looks like:
03 Boxster
Old 02-09-2014, 01:19 PM
OR:
03 Boxster
Old 02-09-2014, 01:20 PM
What's the benefit to these?
Old 02-09-2014, 01:51 PM
It just has a different Core Configuration. Core configuration is how the magnetic path inside the coil is designed.
The most common path used is the "I" core, or Rod Core. This is the round coil. But some modern coils are using a more continuous magnetic path configuration. Using a "Double-C" core or an "EI" core design (also known as E-core) improves the efficiency of how much primary stored energy is transferred to the secondary side of the coil. This design can improve efficiency of the coil.
03 Boxster
Old 02-09-2014, 02:37 PM
