R-12 to R-134a parts.
I just bought a retrofit valve conversion kit for my 3.2. I installed the low side no problem but the high side valve on the Nippondenso is the same thread size as the low side.. So do I just get another kit and install the same valve as the low side and make a note which side is the low side for filling? Thanks, Nick
Sorry, going from R-12 to 134-a.
that won't work because the r134 quick connects are 2 different sizes.
you could do it if you got an extra low side hose so you used 2 low side hoses, just be careful when connecting wait til you try to use an old r12 type vacuum pump with 134 gauges. i searched 2 towns to find an adapter. some cars had a hi side that was even smaller and you needed another adapter to size it up. |
The right adapter
I guess I just need to find the right adapter for the high side.
I just bought a cheap adapter kit today from Autozone that had 1 low side adapter and what appeared to be 2 different high side adapters, although I only attached the low side to fill the Freon it looked like the high's would've fit fine on my Denso compressor.
You should have a PRO do the initial conversion.
You need this... Binary Switch w/ R-134a Discharge Port 7/16" - A/C Pressure Switch Throw away (Ebay, Craigslist) the binary pressure sensor and use this one.. Male Trinary Safety Switch For Electric Fans - A/C Pressure Switch To control and protect your compressor, and run this new fan.. http://forums.pelicanparts.com/uploa...1371425197.jpg Supply power to the trinary switch fan control element 24/7 |
wwest, all I need is the hi side R 134a connector adapter for my Nippondenso unit. My A/C works great. The adapter kit I bought from Pep Boy's high side adapter did not fit. Low side adapter works great!
that fan looks interesting, where did you get it?
Pretty sure it's a spal which are great fans.
Nick,
When you shop for your R134a adapters its best to use the type that have their own schrader valve inside (you remove the the schrader valve from the R12 service port and screw the the R134a adapter onto it). The less expensive R134a adapters simply have a pin which is suppose to push down on the R12 service ports schrader valve. This less expensive design tends to have issues; fails to engage the pin or gets stuck. |
"..my A/C works great..." For the moment.... Buy a little insurance. In case of refrigerant leakage the switch's low cutout will prevent compressor damage. You're converting to a refrigerant that operates more optimally at high system pressures, the switch's high side cutout will prevent the compressor from over-pressurizing the system in the event of a (common) thermostatic control switch failure or malajustment. The extra trinary function is typically used to power the, a fan, fans... Why... 1. Not powering the fan(s) until the high side pressure reaches a more optimal level increases the system efficiency, possibly making up for the cooling capacity lost in the conversion to R-134a. 2. The single MAJOR shortcoming of the factory design is the poor refrigerant condensing capability during periods of extended low RPM engine operation. Adding the fan as shown, or even just powering the front lip condensor fan with the new switch might help to overcome the factory design shortcoming. 3. It is well known that our Porsche's suffer from refrigerant leakage over the long term. Seemingly, 2 years is typical for the US norhern reaches, 6 months in the hot and humid mid-south. What the cause for this leakage has been long though, assumed, to be our legacy "non-barrier" hoses, statements by the EPA, SAE, and DuPont, seem to put the "lie" to this. In consideration of that information it might be wise to adjust our thinking to the possibility that other parameters, parameters other than simply the legacy non-barrier hoses, might be in play. Possibly parameters UNIQUE to our air-cooled engine cars with the primary refrigerant condensing capability mounted directly over a HOT, HEAT-SOAKED, engine and exhaust. Ford prevents extreme pressure excusions, beyond 250 PSI, of R-134a via a "vent-to-atmosphere" suction side (SUCTION SIDE..??!!) pressure relief valve. Historically even with R-12, pressure excursions above 350 PSI, or even as high as 450 PSI, were prevented the same way, "vent-to-atmosphere" BOVs. So, all those FACTS considered, what pressure level might our "unchecked" systems rise to post R-134a conversion given the location of the primary refrigerant condensing "container". Beyond 450 PSI, possibly well beyond, could, SHOULD, be assumed. An "after-run" cooling fan capability might well alleviate our historical refrigerant leakage problem, even if only the front lip condensor fan is used. |
Kuehl, thanks for that adapter info. wwest,, I just need the adapter. You don't know my situation. Thanks anyway. Nick
What question for the original PO were you trying to answer.
LOL Quote:
The more this stuff perpetuates the less I care about being a "gentleman". I squared off with Sucker Fish last year. Ain't heard much from him since. Do a search. I kin' get real stupid. However, wwest did post jokingly about the 800 psi before editing it out this afternoon. I think he has a soft side even though a head-strong stinker. I am not ready to smoke him out of the hole yet. |
Well, there is that.
Edit, I do like screed. I looked it up. ....a long discourse or essay, especially a diatribe Crap - now I have to look up diatribe: a bitter and abusive speech or piece of writing Yep - with you. |
LOL, nice.
The English languange can be so colorful. And in written form, the insults can be sublime.. |
http://forums.pelicanparts.com/uploa...1371514994.jpg |
You gents are right about the pollution of the a/c threads - hard to believe that every a/c related topic, even one as simple as a specific question about fittings, now includes posts, with pictures, about SPAL fans and pressure switches! |
| All times are GMT -8. The time now is 12:26 AM. |
