Which spark plus to use with Perma-Tune?
My 77 911 2.7S has a Perma-Tune spark ignition box. Does anyone know which spark plugs to use? Underneath the model.
Old 06-21-2013, 05:56 AM
T77911S's Avatar
bosch copper plugs. (W5...)
i would really consider replacing that with either an MSD unit or the original bosch unit.
(and coil)
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 06-21-2013, 06:03 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Don't gap the plugs to sixty thousandths of an inch because you read where that will work.
Keep the gap much closer to stock.
Also, on the Permatune box............. What T77911S says. Replacing the P Tune is good insurance you will not be stranded. It's a roll of the dice if you keep it on - and it may go forever - some do, many don't.
1981 911SC Targa
Old 06-21-2013, 06:13 AM
RETIRED
Joe Bob's Avatar
They don't call them PermaCrap for nothing.
Use the cheap, copper plugs...you can find 3 or 6 pin rebuilt Bosch units for 3-400.
2012 ML350 3.0 Turbo Diesel
Old 06-21-2013, 11:04 AM
T77911S's Avatar
if the W5 fouls on you, go with a W7
RACE CAR:: sold
Old 06-21-2013, 11:13 AM
Functionista
manbridge 74's Avatar
I believe the factory used Perma-Tune in the mid 70s...
Permatune 3 Pin box , factory in 1975
Older boxes are apparently robust and repairable.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 06-21-2013, 11:14 AM
