Case Number Question
Porsche 911 SC newbie. Was looking at the case number on my 83 Cabriolet and noted the case number which is 930-101-104-4R. Does this tell me anything? Trying to figure if the engine is correct for this year. Where is the engine number located?
Old 07-04-2013, 03:02 PM
Porchcar guy's Avatar
Look on the right side of the intake fan . It is in a vertical position
15 year PCA member
1972 911 E Coupe - gone now
1987 Mazda RX-7 2+2 - still cooking
Swift DB-1 FF & Swift DB-3 F2000 -not forgotten
1979 911SC 3.0 & 2000 Camaro
Old 07-04-2013, 03:04 PM
Wow, that's not immediately visible. 64D3271
Old 07-04-2013, 03:20 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Yes it does. The engine type should be 930/16.
How about some pics of the car
Who Will Live... Will See
Old 07-04-2013, 04:22 PM
Here ya go!
Old 07-04-2013, 06:29 PM
JJ 911SC's Avatar
Looking good.
Do you have the Owners Guide?
Old 07-04-2013, 06:34 PM
I do not.
Old 07-04-2013, 06:51 PM
S2GART's Avatar
Post a picture of the engine and we can tell you if it's correct or not. Short of that, if your air filter housing lays across the top of the engine and you have individual hard fuel lines going to each cylinder, you have the correct 3.0 engine. 1983 was the last year of the 3.0 engine. Now as far as your particular engine being the original engine for your car, only a copy of the original window sticker or a Certificate of Authenticity from Porsche will tell you that.
If your engine has a square air filter box, positioned on the right side of the engine, then someone put a 3.2l engine in.
Pictures are best
The "collection"
1983 911 SC Targa (1 of 1430 imported)
1994 MB E320 Coupe (1 of 825 imported)
1992 MB 190E 2.6
2004 Volvo V70 2.5 Turbo (1 of a bazillion imported)
Old 07-04-2013, 07:20 PM
