Nico911's Avatar
How does it work - heat exchangers
Hi guys.
I'm trying to figure how does hot air ends up in the cabin on a early 911 (let's say we're talking about a 3,2 Carrera). I mean, I guess the air is heated but the the engine (while cooling it) but I don't get what the heat exchangers are for... ?
Thanks for clarifying that for me.
Nico
1985 911 Targa (sold)
2001 996 Twin Turbo (sold)
2001 996 C4
Old 06-28-2013, 08:28 PM
Banned
that big ol fan in the engine bay .. blows the air over the exhaust headers up thru the rockers inside the car. all types of swtiches and leavers to STOP it .. yes it gross. unless it new and oil free.
996 has a nice heatting system
Old 06-28-2013, 08:32 PM
There's tons of descriptive info on how airplane heaters work. Same thing. That may be easier to understand
Old 06-28-2013, 08:40 PM
Rescuer of old cars
Arne2's Avatar
Heat exchangers are air chambers that encase the exhaust headers. On a 3.2 the air is forced down into the exchangers to be heated by the headers, and from there up into the tunnel and into the passenger compartment. The function of the exchangers is to keep the air that is being heated separate from the outside air, trapped in close proximity to the headers.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 06-28-2013, 08:41 PM
El Duderino
tirwin's Avatar
And as long as you have no exhaust leaking in, it works great. Almost too great...
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 06-28-2013, 08:50 PM
Nico911's Avatar
Great ! I'm learning...
So is there a continuous flow that brings air to the heat exchangers ?
And how the air that is forced in by the fan to cool the engine exits ?
2001 996 C4
Old 06-28-2013, 08:59 PM
What?
Eric Hahl's Avatar
The levers in between the seats allow you to direct the air into the cabin heating system or to bypass the system and dump the hot air out underneath the car.
________________________________________
Eric Hahl
85 911 to 73RS backdate, a.k.a. "Gretchen" (SOLD)
2015 981 Cayman S (Sold)
23 Outback Wilderness & 23 BMW R1250GS
Old 06-28-2013, 09:04 PM
tazzieman's Avatar
As long as that fan operates , air is forced past the exhaust and along the duct towards the cabin. Where it goes next depends upon whether you have the levers beside the seats up or down.
The other pathway for fan air is over the cylinders and out under the car.
HE : imagine a sealed hot water pipe. Thread a larger diameter pipe over the top and blow through one end. What comes out the other is what heats the cabin.
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 06-28-2013, 09:05 PM
Senior Advisor
James Brown's Avatar
it's called a air-to-air heat exchanger. cool air traveling past hot pipes, like a crude intercooler in reverse. just like the old VW's or big jets. simple and it works
08 Cayenne Turbo
Old 06-29-2013, 12:17 AM
1986 930's Avatar
Let me assure you that you can cook yourself right out of an older Porsche with those heat exchangers in just about any winter climate unless you are down in the negative degree F range. I would roll down the windows with the heat maxed out on cold Midwest days when I lived in Oklahoma years ago. (20-30 degrees F)
They work very well and give you that wonderful smell of an old Porsche. (That also extends to air cooled VW Bugs which I am a big fan of as well. Yes, I know, sacrilege!)
The neat thing about '89 or older 911s is that you can put the heat on your feat and some fresh air on the uppers and be real comfy since the heat and fresh air vents work independently.
Mark
1986 930 Ultra-Smith/RUF Slant Nose conversion, 3.4 BTR Spec, K-27HFS, RUF IC, TIAL .9 BAR Waste Gate, 930 4 speed transmission, RUF Front Oil Cooler, RarlyL8 Headers, RUF 4 Pipe Exhaust
Old 06-29-2013, 03:24 AM
And how the air that is forced in by the fan to cool the engine exits ?[/QUOTE]
The belt driven fan blows some forced air through a duct to the electric heater fan and some (most) over the cylinder fins to cool the engine. The air that cools the engine exits out the bottom of the cylinders and oil cooler and is not the air used for cabin heating. The cabin heating air flows past the electric fan, through hoses, through the heat exchangers, up to the heater valves and is either dumped out or directed to the cabin based on the levers by the hand brake. An important point to recognize is that the exhaust pipes in the heat exchangers are cooled by a large constant flow of air, even when the heater is not on. Heat block off plates are sometimes marketed as "improving cooling" which is nonsense, cylinder head temperature and detonation increases when you block off the flow to the enclosed header exhaust pipes. Porsche knew this and some later models have a thermostatic switch to turn on the electric booster fan to prevent overheating.
Paul
Old 06-29-2013, 09:39 AM
Paul,
Good reminder to all. What is equipped on a race/track car (e.g. open headers, minimal/no air filters, roll bar next to bare head, etc.) may not be conducive on a street car.
Sherwood
Old 06-29-2013, 12:30 PM
