Found my clutch problem
Was driving great one day , and the next it was hard to get into gear and then wouldn't work...
Old 09-09-2013, 09:10 AM
Where do I get a new clutch fork?
Old 09-09-2013, 09:18 AM
So how much "while I am in there" did you do?
Old 09-09-2013, 09:20 AM
I'm still there! I ordered throttle linkage bushings with the fork. Have sume oil leaks, but can't really get to them where it sits.
Old 09-09-2013, 09:32 AM
RETIRED
Joe Bob's Avatar
Been doing any hard launches?
2012 ML350 3.0 Turbo Diesel
tobluforu's Avatar
What the hell is that in the right side garage spot?
Old 09-09-2013, 09:52 AM
No hard launches...only owned it about a month.....it's a Toyota!
Old 09-09-2013, 11:00 AM
Is there a write-up anywhere on replacing the clutch fork?
Old 09-09-2013, 11:12 AM
Capitalist and Patriot
911Freak's Avatar
There is a small dowel to punch out in the clutch fork as it mounts on the shaft. You drive it out towards the bell housing and pull it out with pliers.
Make sure to order the shaft seals x 4, and make sure to clean and lube the clutch shaft as you put it all together. I use copper anti seize or white lithum.
Drop the C clip from bottom of shift fork shaft where the omega spring assembly is and if your lucky the whole assembly drops off after you remove that fork dowel.
Many many threads on this.
UTSF and you will find them or check the 911 tech articles.
1 hour job tops if you have everything.
I ordered my shift fork and shaft seals from..... Pelican!
Who else?!
Good luck.
Old 09-09-2013, 11:21 AM
pete3799's Avatar
Drive out the roll pin (visible in your picture) slide shaft down, replace fork.
Pete
79 911SC RoW
Old 09-09-2013, 11:23 AM
I polish all the casting flash off the new forks to help stop stress risers and possible future cracks. Gled
Old 09-09-2013, 11:59 AM
