| Registered |
				Found my clutch problem
			Was driving great one day , and the next it was hard to get into gear and then wouldn't work...   | ||
|  09-09-2013, 08:10 AM |
| Registered |   Where do I get a new clutch fork? | ||
|  09-09-2013, 08:18 AM |
| Get off my lawn! |
			So how much "while I am in there" did you do?
				__________________ Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! | ||
|  09-09-2013, 08:20 AM |
| Registered |
			I'm still there! I ordered throttle linkage bushings with the fork. Have sume oil leaks, but can't really get to them where it sits.
|  09-09-2013, 08:32 AM |
| RETIRED |
			Been doing any hard launches?
				__________________ 1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel | ||
| Registered |
			What the hell is that in the right side garage spot?
				__________________ 72 911 Although it is done at the moment, it will never be finished. | ||
|  09-09-2013, 08:52 AM |
| Registered |
			No hard launches...only owned it about a month.....it's a Toyota!
|  09-09-2013, 10:00 AM |
| Registered |
			Is there a write-up anywhere on replacing the clutch fork?
|  09-09-2013, 10:12 AM |
| Capitalist and Patriot Join Date: Sep 2006 Location: Freedomville
			There is a small dowel to punch out in the clutch fork as it mounts on the shaft.  You drive it out towards the bell housing and pull it out with pliers.  Make sure to order the shaft seals x 4, and make sure to clean and lube the clutch shaft as you put it all together. I use copper anti seize or white lithum. Drop the C clip from bottom of shift fork shaft where the omega spring assembly is and if your lucky the whole assembly drops off after you remove that fork dowel. Many many threads on this. UTSF and you will find them or check the 911 tech articles. 1 hour job tops if you have everything. I ordered my shift fork and shaft seals from..... Pelican! Who else?! Good luck. Last edited by 911Freak; 09-09-2013 at 10:24 AM.. | ||
|  09-09-2013, 10:21 AM |
| Registered |
			Drive out the roll pin (visible in your picture) slide shaft down, replace fork.
				__________________ Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey | ||
|  09-09-2013, 10:23 AM |
| Registered Join Date: Feb 2009
			I polish all the casting flash off the new forks to help stop stress risers and possible future cracks. Gled
|  09-09-2013, 10:59 AM |
