87 3.2 Carrera Brake Issue
Hey guys,
I'm a new owner of an 87 Supercharged 3.2 Carrera and have been getting to know it over the last couple of weeks. One of the things I've noticed is that the brake pedal pressure it's extremely stiff (which is normally fine) but the stopping power is very lacking. There is no brake squeal whatsoever, just poor stopping power. Is the system likely in need of an upgraded pad? The braking strength is so poor I can't believe this is anywhere close to how it left from the factory.
Current
1999 Subaru Impreza Widebody (JDM V7 STI swap) | 2009 BMW E92 M3 | 2002 Honda S2000 | 1972 Honda CB350 | 1969 Honda S90
Old 09-21-2014, 12:34 AM
Originally Posted by popngear View Post
...., just poor stopping power. Is the system likely in need of an upgraded pad? The braking strength is so poor I can't believe this is anywhere close to how it left from the factory.
Do you know the "history" of your car? You're correct....brakes are "awesome" on these cars if functioning properly. Personally, I'd do a complete R&R....new rubber brake lines (at the calipers) if they are still original, flush/replace fluid, new pads, etc. It's a fairly easy DIY project for a new owner imo.....good luck!
Old 09-21-2014, 02:27 AM
Bill Verburg's Avatar
Hey guys,
Check to see what m/c is installed
stock is a 20.6
some owners throw a 23.8 from a 930 on, this makes for a lot of effort for any stop.
another possibility is pads, for street use a street pad should be in there
Bill Verburg
Old 09-21-2014, 05:55 AM
MConn's Avatar
Put your foot on the brake pedal, and start the car - if the pedal feel doesn't change, your vacuum assist on the master cylinder may be bad, the pedal should go down once the engine vacuum helps push on the pedal. I have a car with a bad vacuum assist, and if seems like the brakes don't work as well as the car I have with a working vacuum assist.
Mike
The more I learn, the less I know.
Old 09-21-2014, 09:22 AM
Mike
that would do it too, one failure mode is for the booster to fill w/ b/f
Bill Verburg
Old 09-21-2014, 01:15 PM
Mike
I tried this out and the pressure does not change. Is there an online DIY on how to remedy this? Thanks for the advice doctor.
Current
Old 09-21-2014, 08:03 PM
Bump ... anyone have a DIY on fixing a bad vaccuum assist?
Current
Old 09-22-2014, 10:52 PM
Pull the vac hose off the booster and see if there is vac there. You can use a vac gauge but it's pretty obvious if there is vac or not.
Th booster can or m/c are the most likely failure points, If unfamiliar w/ basic diagnosis take it to a shop that knows 911s
Bill Verburg
Old 09-23-2014, 03:46 AM
69-912-swt's Avatar
Would having a Supercharger have anything to do with it ?? Doesn't the vacuum on a na-3.2 come from the intake manifold ??
Bill Kent
https://www.facebook.com/#!/NoSweatPhotography
1987 Carrera Targa
1969 912 SWT #0053
Old 09-23-2014, 04:45 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Yes, Vacuum does get pulled from the intake manifold.
As far as OP's brakes, check to see if there is a leak in the brake line system, especially under the stone guard, there are T fitting and a straight fitting thru the tunnel, that may be leaking if not at the calipers.
'85 Carrera Targa
PCA/POC
Old 09-23-2014, 06:31 AM
scarceller's Avatar
The super charger may be related, check closely what may have been altered on the line that feeds the Brake Booster. This vacuum port is located on the rear of the LHS intake chamber, right above cyl #3. At the rear of that chamber it has a big port that feeds the hose to the front master cyl. Can you take a photo of that plumbing so we can compare to the stock setup?
When they super charge they need to address this area since under boost you'll feed positive pressure to the brake booster, not good idea. So if they did nothing top help with this you'd pressurize the master cyl with whatever PSI the super charger can deliver.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 09-23-2014, 08:19 AM
Yup. The brake booster isn't working. It could be one of the many issues associated with adding a supercharger to a N/A 911.
The Cap'n
Old 09-23-2014, 08:35 AM
Diss Member
Quicksilver's Avatar
A supercharged system will still create vacuum at idle otherwise it wouldn't slow down to an idle.
So the big question: Is the throttle butterfly before or after the supercharger?
If it is before you will simply need to make sure that the brake vacuum is coming from between the butterfly and the supercharger.
If it is after you will want to make sure there is a vacuum check valve near the vacuum port to retain vacuum in the system. You may need a vacuum reservoir (which often contains the check valve.) so there is more vacuum available for the system. In extreme cases you might need a vacuum pump.
But ... (there is always a but)
It sounds like you system is just kaput so the questions are:
- Is it hooked up? Simple vacuum test at idle by pulling the hose at the brake booster and seeing if it is sucking.
- If it is sucking then obviously the booster must be toast. So does the system have a vacuum check valve? The booster wasn't designed for a pressurized system so the boost could damage it.
The questions about vacuum reservoir would be asked after the basic system is working. Try tapping the brakes a couple times with some left foot braking while you are at cruising throttle. If it doesn't brake consistently then a reservoir would be a good idea.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 09-23-2014, 11:15 AM
Travis Neff's Avatar
This may be of interest!
vacuum leak you probably didn't ever think of
Old 09-23-2014, 12:38 PM
scarceller's Avatar
Could have been damaged if the super charger pressurized it. How much boost we talking about 5-7PSI? You really need to see if anything was done to prevent pressure from being seen by the brake booster, like a 1 way check valve? If nothing was done to assure no pressure ever gets to the booster you can easily destroy another new Brake Booster. Who did this super charger?
The Cap'n
Sal
1964 356SC (SOLD)
Old 09-23-2014, 05:11 PM
Thanks for all the suggestions and info, much appreciated. The supercharger is made by Paxton though I can't photograph the setup right now as the car is currently in Vancouver (I live in the Seattle area). To answer the boost question, the setup runs maximum of 5psi. Lots of awesome suggestions, the cheapest ones which I will start with first
Current
Old 09-25-2014, 12:44 AM
guys i have the exact same issue on my carrera / no supercharger..
I have no brake assist. i replaced all brake lines on the calibers- and what allso happens is on my rear calipers they stick a little for couple minutes before releasing.. now couple weeks ago one really got stuck.. and it destroyed my disc because i still had to drive home while it was stuck.. meaning big overheading of the disc+ brakepads etc..
Now i replaced the entire caliper+ brakepads But it still sticks after a lil driving..
Now before i replace the disc i want to fix it..
Any ideas im not familiar with vacuum etc i still have to replace all the fluid because i have noo idea how old it is..
Old 01-25-2015, 02:05 AM
DRACO A5OG's Avatar
Sounds like you may need to rebuild the rear calipers. Next time this happens do not drive her. But in a pinch, use your lug nut wrench and press the brake pedal down about 2 inches and open up the bleeder valve to hopefully release that frozen caliper and carefully drive home or better yet have it towed.
'85 Carrera Targa
PCA/POC
Old 01-25-2015, 10:49 AM
yes but my brake booster is allso not working.; and i have replaced both rear and front calipers..
Old 01-25-2015, 12:14 PM
