Post How much time to replace dash
I have a new dash for my 1980 911SC and was wondering how many hours it take to replace. I realize I (or glass shop) need to remove the windshield, so taking that into account whats the verdict. This forum is great, and thanks in advance.
Old 08-24-2001, 12:25 PM
Post
Jerry,
I would estimate a couple hours. It doesn't require much however I had to fabricate mine due to the larger vents from the '86 dash I used. This estimated time is based on after the removal of your windshield. I removed the windshield myself but had a professional re-install it.
Good luck!
John
'81SC Targa
Old 08-24-2001, 12:43 PM
wckrause's Avatar
Post
Two hours sounds about right. A small ratchet set is usefull for getting at the bolts, and you will need the proper plastic clips for the top of the dash.
Bill Krause
'79 911SC Euro
MY PELICAN GALLERY
Old 08-24-2001, 01:45 PM
Question
Is this the $1000 replacement dash or is there more resonable product out there that dosen't look it's form a flea market. I have a cracked dash and cracked windshield.I would like to fix this in one shot. I just can see paying $1000 for a dash.
NATE '72 911 TARGA
Old 08-24-2001, 10:04 PM
Post
The dash I got was in very good shape(1/2" crack at defroster vent) for I think $140.00 on e-bay.
Thanks again for the Info
Old 08-27-2001, 09:56 AM
APKhaos's Avatar
Post
Got a question for you guys that have replaced a dash.
Picked up a rare [blue] dash which is crack free, but the vinyl 'extensions' around the edge are rock hard, brittle, and badly wrinkled up. These 'extensions' cover the gaps between the edges of the dash panel and the window rubbers, right? So I'm thinking that the replacement is going to look terrible unless I can find a way to restore or replace these extensions. I've tried soaking them in Vinylex - no luck.
Any one faced/solved this problem???
Tony K
85 Carrera
Old 08-27-2001, 12:46 PM
Post
Tony:
Since the window rubber is black, maybe you could trim them off & glue some black vinyl in place of the blue. Maybe it would blend right in.
Old 08-27-2001, 01:24 PM
APKhaos's Avatar
Post
Marv,
Good idea. Would need to find a miracle glue that would be SURE not to fail - extremes of temperature etc, and a real PITA if it were to fail. Might me tricky to get it looking good. Sounds like a trip to my local interior guy is coming up.....
Thanx,
Tony K
Old 08-27-2001, 03:14 PM
Post
steam, or a heat gun will soften vinyl. don't get too carried away with the heat gun as it'll melt or burn stuff. heat guns are good for removing depressions or dents from dash pads and mouldings.
Old 08-27-2001, 05:59 PM
