Can anyone help..
I have just bought a '82 911sc coupe and it runs great when motor first starts out. I can drive it for 10 miles and everything is fine. Stop and start again and it acts up with low idle and slow accelleration and during long hauls. Could the problem be that the distributor advance is sticking? The car was only driven 500 miles in one year, could it be bad gas? Or could it be a simple adjustment of the fuel mixture? Has anyone had this problem? |
Since my 82sc had that low hunting idle, I disconnected the O2 sensor (Black 1/2" dia plug just ahead of CD unit) I could not believe the difference. You will probably have to adjust your idle speed after this.
Sounds like mixture, but as a new owner, you should go over the basics.
1. Check ignition timing. 2. New plugs. 3. New cap and rotor. Remember to oil the distributor, under the rotor. 4. Get a shop to set mixture using an exhaust gas analyzer. A lot of SC owners disconnect the O2 sensor (and still pass emissions). ------------------ Bill Krause '79 911SC Euro MY PELICAN GALLERY |
what you have most likely, is a intermittent relay problem. if the relay that operates the lambda computer under the passenger seat fails, the car will run exactly as you describe. it gets it's power from the domelight fuse. it sits next to the computer against the tunnel. it's a $5 part, so replace it and find out. the computer needs to work regardless of the oxy sensor being connected or not.
It is under the passenger seat next to the computer with a 6 wire connector on it.
would any know the part # of that relay that john walker mentioned in this post.
lambda sensor relay? thanks Jason 81 SC |
relay #821.951.253. it's a universal relay. lots of uses. this one just has a mounting tab on it.
do tell, where did you get it?
is there another part # Jason 81 SC |
[QUOTE]Originally posted by jason1guy:
do tell, where did you get it? is there another part # Jason 81 SC[/QUOTE Bosch part #0332-019150 and Echlin cross ref part #AR230 which I got at a local Napa parts store. |
