| Bristol Cities |
				SC airbox question?
			Hi Guys, I was replacing my air filter last night when I noticed this hose fitting (circled below), on the driver side of the airbox after the filter, that has no hose connected to it. I could not find any hose near by that had fallen off and it seems that unfiltered air can get through here. I did some searching on here and in my Bentley with no luck. Anyone know that this is for? The PO did a cruise control delete and I'm thinking it may have to do with that. Thanks [IMG]  [/IMG]
				__________________ 1983 911SC   | ||
|  07-12-2013, 08:19 AM |
| ROW '78 911 Targa |
			Not used, Mine has a small rubber plug that fits in it to block it off. Fill it with silicone and let it sit for 24 hours or find a cap that goes over it. A vacuum fitting cap will work.
				__________________ Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. | ||
|  07-12-2013, 08:47 AM |
| Bristol Cities |
			Got it.  Thanks for the info!
|  07-12-2013, 09:34 AM |
| Chief Head Scratcher Join Date: Apr 2009 Location: Bainbridge Island, WA
			That is hooked up to the charcoal canister at the right side of the engine bay.  Part of the fuel emissions system.
				__________________ John Morris '79 911SC | ||
|  07-12-2013, 09:41 AM |
| Registered Join Date: Feb 2001 Location: South of the Mason-Dixon Line
			On my 1973.5T (first CIS) I have the identical fitting on my airbox. The fitting is for the hose that comes through to the rear from the charcoal cannister/vapor recovery jug in the front of the car (my model). I removed the hose from the box although its still near the firewall and plugged the fitting on the airbox.  Many years since the 73.5T to your SC model. I would assume its for vapor emission return somewhere!  Bob 73.5T | ||
|  07-12-2013, 09:44 AM |
| Registered Join Date: Feb 2006 Location: Ontario Canada
			that is the vapour recovery port ... as mentioned .. but i am way more interested in WTF this is !!!!!! ??
				__________________ 1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) | ||
|  07-12-2013, 09:55 AM |
			undo the straps and remove the boot (slowly) and check it out. Looks like you might have a crack in the air boot and someone took the cheap way to a repair and sealed the crack. If thats the case....replace the boot!!!!!!!!!!!
|  07-12-2013, 10:11 AM |
| Bristol Cities |
			[QUOTE=theiceman;7544604]that is the vapour recovery port ... as mentioned .. but i am way more interested in WTF this is !!!!!! ?? I was wondering if anyone was going to notice that. I think the PO used gasket maker to plug a crack in the boot. I already ordered the new boot from our host and was going to install this weekend. Do you think I can replace it without removing those fuel lines or lowering the motor?
|  07-12-2013, 10:13 AM |
			[QUOTE=Guvnor;7544653]
 its a bit tricky feeling around the back to unscrew a couple of hoses but i take mine off every couple of years to clean it up and make it look perdy
|  07-12-2013, 10:22 AM |
| Senior Member Join Date: Nov 2000 Location: Great NorthWest
			Okay, when the car is running and you remove the oil cap, does the idle drop? If so, good; if not, an air leak. That plenum (rubber boot) is toast - toss that in the trash where it should have ended up long ago. The PO probably wrestled the plenum off the throttle body and caused the split. Get a new item whose rubber is pliant. EDIT: If there was no plug in that hose fitting, I just don't know how your car even ran? If you plug it, there will be a few adjustments you will have to make to adjust to the loss of straight-air input AFTER the air filter. Wow - that might explain the messy detris in the bottom of the airbox (clean all of that up BTW). Also, interesting that you have solid fuel lines (metal) instead of the "plastic" types employed for our '78s. Is that the correct engine for your model year?
				__________________ '78 Targa in Minerva Blue Last edited by Jdub; 07-12-2013 at 11:40 AM.. | ||
|  07-12-2013, 11:36 AM |
| Taking it apart is easy Join Date: Nov 2009 Location: rural Quebec, Canada
			The worst part of this situation is getting unfiltered air, and the dirt that goes with it, into the engine.  Since this dirty air is (was) getting introduced before the whole fuel injection system has its way with it, you need not worry about a 'vacuum leak' and there will not be any adjustments to do once you plug the unused port. Correct, it is the port that once connected to the charcoal canister.
				__________________ Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com | ||
|  07-12-2013, 12:15 PM |
| Bristol Cities |
			Thanks Jdub.   Yes I'm fairly sure that the boot is leaking gobs of air at the hose fittings in back. I can plug the air intake (in front of air filter) with my hand and the engine runs fine with no dip in RPM. Also no change in RPM with removal of oil cap. I think the solid fuel lines are correct for 83. Was the last year of CIS so they really pulled out all the stops
|  07-12-2013, 12:19 PM |
| Registered |
				It's an 83 SC.........
 You have the older '78 SC like mine and the OP has the '83 SC model with metal fuel lines. That hole from the side of the air box is allowing unfiltered and unmetered air but it is before the metering unit. So no adjustment NEEDED contrary to your suggestion. Tony Edit: Pete caught the blunder in my post. And made the necessary 'adjustment'. Last edited by boyt911sc; 07-12-2013 at 03:10 PM.. | ||
|  07-12-2013, 02:22 PM |
| Registered |
I think Tony meant to say unfiltered and unmetered air.
				__________________ Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey | ||
|  07-12-2013, 02:56 PM |
| Registered |
				Ooooops!
Thanks Peter for catching up the blunder!!!! I'll go correct it. Tony | ||
|  07-12-2013, 03:01 PM |
