911canuck's Avatar
Wrong caliper ?
Hi, I'm rebuilding a 1974 Targa (Base Model); after a complete teardown I'm putting everything back together. Did change the rotors, and sent out all calipers for rebuilt.
FRT RH re-install went well; but FRT LH is a different story.... I wasn't able to install the caliper because of interference with the disk. At first I thought it was a questing of the inner bearing not being seated correctly. Put back the hub on the press; nothing moved. By looking carefully at the caliper itself I've noticed that the clearance was about 0.100" less on the LH then on the RH
Casting #:
RH (ATE)
Outer: 45P
Inner: 10R
LH (ATE)
Outer I88
Inner: 33
Spacer thichkness is equal on both sides.
Lastly, the rotors removed (maybe because of wear were significantly thinner:
Old: 0.735"
New: 0.805"
Any guidance would be appreciated, Thanks
Old 07-14-2013, 01:55 PM
RETIRED
Joe Bob's Avatar
Have you talked to the vendor that did the work?
2012 ML350 3.0 Turbo Diesel
Old 07-14-2013, 02:47 PM
