DennisS (guest)
Guest
Posts: n/a
After having my car stored for a few years, I went through the process of restarting it. Change plugs, change oil etc. It did start and run well. However smoke began to pour from the vents and I stopped the car. Upon investigation I found fried wires:all of the grounds to the instruments except the clock and the green / white wire that goes to a light on the gauge to the light switch. This is the cars first electrical problem. I can probably rewire things but my big concern is figuring out why this happened.
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-10-2013, 10:28 PM
Rodents have been known to get into cars and chew on the wiring. I don't know what you mean by "all of the grounds to the instruments" Where the ground wires leaning on the engine or exhaust? Did they burn up without touching anything? If they did they were carrying too much current. Fuses should have blown to protect the circuit. The ground may have corroded and the drop in voltage increases the amp draw. Try cleaning all your grounds.
- Kerry
Send a message via Skype™ to Porboynz
That's a classic problem, the instrument light feed is not fused. I planned to fit a fuse to mine, bought the inline fuse, read up about it on the forum and put it off. Now having read this post its top on my list.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 08-11-2013, 12:34 AM
The Problem
I traced the burnt green/white wires to the light switch. Then I removed the light switch and found it was burnt on the windings next to the green/white wire. So I would say the light switch failed at the power to the lights, so all the green/white wires have been effected and the brown ground wires at the instruments. All other wires were okay.
Yes an inline fuse wound have halted this from happening.
So I am gathering the information to replace these wires and the light switch. I also will include a fuse in case there was another problem. I will only use the fuse.
The actually is a lot of information on this site and the internet in general regarding the layout of the instrument wiring and the other car lighting.
Old 08-11-2013, 07:26 AM
al lkosmal's Avatar
+1.................I've been there and done that with my 77S. The lack of a fused circuit ....all you need is one short from power to ground.........and you let the smoke out. Rep0lacing all the burnt bits and adding a fuse is the way to go.
regards,
Al
RGruppe #669
http://www.x-faktory.com/
Old 08-11-2013, 08:45 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Ventilation slider controls.
On some occasions, the dash light 12V wires can ground on the sliding controls.
Do add a 3A fuse, and check my previous post on fusing, and headlight switch wire connections.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 08-11-2013, 08:49 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Our cars are old!!
The wiring has been in that car for decades (in most cases).
Wiring can chafe (rub against bad metal objects) from years of vibration.
So...when looking at your wiring...and you should on a regular basis...be careful when bending or moving the bundles...they may be OK where they are...but if you touch them..you might be putting them in harms' way.
I have seen lots of old wires that were so brittle...the insulation would fall off if moved (good old Lucas wires..prince of Darkness...LOL).
If in doubt...replace as much of it as you can...with new (and sometimes better or bigger wires)....and definately...FUSE EVERYTHING!!
Bob
Bob Hutson
Old 08-11-2013, 08:53 AM
