Immature Member
dentist90's Avatar
Question Three door plug questions...
Hi guys I've repainted my 84 and am in the process of putting all the pieces together. I have a few questions about covering the holes in my passenger side door. ( BTW: the door is from a 964 or other later replacement as it has oval window frame cover plugs rather than the two round ones)
One: I found this rubber plug fallen inside the door but have no idea where it came from. Anyone know where it's from, and why it's so large compared to it's retention barb? Is it a bumper for the window mechanism or something?
Two: I have this huge hole in the front edge of the door (same diameter as the rubber plug above, incidentally). Can anybody tell me what this is plugged with? I can't imagine it was supposed to be open like this... it would let all sorts of weather/crap into the door.
Three: These holes have always been open. I could plug them with 3mm trim plugs, but are they there for a reason? Look like screw holes to me. Anybody have theirs covered?
As always, thanks for all your help over the years here!
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 07-16-2013, 08:14 PM
Immature Member
dentist90's Avatar
Anybody care to look at their own doors to see if they have similar holes and what are in them? Pretty please
Old 07-17-2013, 11:44 AM
Tired Member
DaddyGlenn's Avatar
Isn't the hole in the second picture for the window/mirror wires?
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 07-17-2013, 12:07 PM
wrxnofx's Avatar
Comments on the 3 pics:
1. I don't know what that plug would be for.
2. I don't have a hole like that on the driver's door of my '87, and I can't get the door open far enough on the passenger side to see if I have something like that. I would guess no.
3. Again, my '87 doesn't have those 2 holes:
However, I know I've seen pics of other doors that DO have those 2 holes in them. I have sometimes seen them with nothing in them, and other times I've seen screws in them.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 07-17-2013, 12:27 PM
wrxnofx's Avatar
Here would be the bottom one:
http://dealeraccelerate-all.s3.amazonaws.com/ag/images/2/6/8/268/20338_0bc8fcf550_low_res.jpg
Old 07-17-2013, 12:30 PM
Immature Member
dentist90's Avatar
@DaddyGlenn: thanks for the inspiration. I rechecked my 964 PET and it shows a bellows-type protector for the 964 wiring harness. Our wires come thru the door via three grommet holes ahead of this big hole. This big hole is obviously for the 964 door/mirror/window wires. My door either had all these holes pre-drilled or the three smaller ones were drilled after the fact. Regardless, I haven't been able to find a listing for a plug this big so I guess I'll have to find or make one.
@wrxnofx: thanks for your help too! My drivers' side doesn't have those two little screw holes like the psgr side does. No problem, I found some Chrysler plugs that do the trick nicely. Thanks again!
Now if I just knew what that other big rubber plug was for... it's bugging me because I don't want to seal up the door and then find out it prevents the window from rattling while it's down or some darn thing like that.
Old 07-17-2013, 07:23 PM
Big hole is for wiring bundle as stated above. The 2 little holes secure plastic covers inside the door that protect the latching mechanism. These started I think on the 964.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 07-18-2013, 10:42 AM
Immature Member
dentist90's Avatar
Thanks RSTarga. No inside cover in my door so I'll plug them. The only question now is that
40mm rubber plug. Maybe it's not from this door? (but it was inside it when I took the old vapour barrier off). The barbed bit fits in a door clip retention hole nicely. If no one with a 964 has seen this in their door I'll just go ahead and close her up. I'm sure I'll sleep again someday... LOL.
Old 07-18-2013, 08:58 PM
