Jp-oh's Avatar
Repaired Odometer - Speedo Lights Not Working
Hi, I repaired my busted odo gear today and after getting everything put back together it all works spledidly.. except the backlights for the speedo. The green parking light works, the speedo and odo work perfectly but the backlights do not work. They seem seated as they should be. I've not checked the bulbs. I've searched and haven't found a solution.
PS 1986 3.2.
Cheers.
Old 07-17-2013, 05:39 PM
ROW '78 911 Targa
timmy2's Avatar
Ground wire connected?
Old 07-17-2013, 06:12 PM
Try rearranging the order of the three lights for the speedo.
Same thing happened to me after I repaired mine. I labeled all the wires correctly but the lights need to be inserted in a certain order.
2007 Cayman
1986 Carrera coupe (sold)
1979 911 SC targa (sold)
Old 07-17-2013, 09:01 PM
Jp-oh's Avatar
I was careful to mark the light positions so they're in correctly. If it was a ground issue would that not also affect the green running lamps bulb? All the remaining wires (8 in total) are attached as in the positions they came from. Porsche uses solid brown for grounds correct?
Old 07-18-2013, 04:13 AM
Jp-oh's Avatar
Bumping this up for fresh new idea time.
Old 07-19-2013, 06:16 PM
porwolf's Avatar
I recently reinstalled my 1979 speedometer after a North Hollywood odometer repair. I als initially did some cross wiring and nothing worked right. Then I went back to the Bentley schematics and got it right. Fortunately I did not burn anything. My two illumination light bulbs were then hooked up to two black and blue wires. They could be tested for 12V with the light switch turned on. If 12V don't arrive at the speedometer illumination bulbs something went wrong down stream. Of course the right brown ground wire has to be connected to the speedometer case. Incidentally later than 79 models also have another wire connected that has something to do with a mileage counter.
Here is my 79 SC speedometer hook-up:
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 07-19-2013, 10:48 PM
Jp-oh's Avatar
Forgot to add the solution for closure. Bulbs
1986 Meteor Grey Carrera - We'll meet again in Valhalla.
Old 10-10-2013, 01:15 PM
86 ssinit's Avatar
How hard was it to change the odometer gear?? How long did it take?
1986 Porsche 911 Targa
1983 911 sc
2015 WRX
Old 10-10-2013, 04:08 PM
Jp-oh's Avatar
It was pretty easy actually. That is so mainly due to the great write-ups found in the forum. It didn't take too long at all and I am by no means a master mechanic.
Old 10-10-2013, 04:28 PM
