Banned
912 part identification .
Anyone know the correct name for this part ?
Old 07-21-2013, 10:05 AM
Shaun @ Tru6's Avatar
Rear sunroof drain tube
Tru6 Restoration & Design
Old 07-21-2013, 10:08 AM
upwardr's Avatar
Isn't that a warm air duct that carries air though the rear seat area to the windows?
Larry
1971 911T
1983 Envemo, Cabriolet
1989 Carrera Cabriolet
Old 07-21-2013, 03:27 PM
I think you are right.
Old 07-21-2013, 03:33 PM
I believe the orange part is a sound insulator for the carb heating system. The shorter black hose fits on the tee connector on top of the dog house. The other end is fitted to the nipple on the right side of the engine compartment. When the heater is in the on position, warm air is routed to the hose and then directed down to the tops of the carbs. It was changed in MY '68 with the warm air routed to tubes positioned under the carbs. Rear window defroster tubes are single tubes, on the left and right of the engine compartment fed from the same heat ducts in the longitudinals.
Tony
Tony
1973 914 2.2 FAT Black
1974 911 Targa Lime Green
2018 Macan GTS White
2019 Targa GTS Agate Grey
Old 07-21-2013, 03:55 PM
here it is from the PET:
Tony
Tony
Old 07-21-2013, 04:02 PM
That also looks like a rear heat tube to the lower corners of the rear window.
Current: 914/6 GT Conversion, Cayman
Old: Many PCars + Formula Racecars
Old 07-21-2013, 04:16 PM
Close, but the defroster hose has a smaller diameter and is fitted to the outlet closer to the firewall.
Here's a pretty good picture of the whole system including the defroster tubes.
Tony
Tony
Old 07-21-2013, 04:27 PM
