Anyone know where I can order power window stops??The ones inside the door which limit how high the window rolls up? I cannot seem to find them anywhere.
Thanks, Jim ------------------ jevose 82 911 SC 88 930 Turbo |
The window stop is part of the lifting mechanism. If the window is too high,
remove the door trim and adjust the stop until you get a good fit against the roof seal (I takeit it's a targa). You will probably have to adjust the glass angle to achieve the best fit. The stop is inside the door on the linkage, look for a rectangular shaped hole in the panel with a bolt head inside..that is the stop. Loosen the bolt and slide it either way, tighten the bolt and try it, if too high move it the other way. It's fairly easy to do. But make sure the targa roof fits properly first. You may have to adjust that before moving to the doors.. The sequence is: 1. Adjust doors to fit body. 2. Adjust targa roof to fit body. 3. Adjust door window frame to fit body and targa roof. 4. Adjust Glass to fit body and roof. 5. May have to re-position lateral seal to fit door glass and frame. 6. Drive and enjoy |
