LinkBack Thread Tools Rating: Thread Rating: 2 votes, 1.00 average.
Cool
Blown......great thread...................Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-05-2002, 07:43 PM
phaques's Avatar
Chuck,
Read your bit on the home-fashioned camber guage, and since my trig is a bit weak, I went to excel to re-create the camber angle table you described. Email me if you (anybody) want me to send you the file. It is pretty straightforward. YOu can modify the wheel diameter in column A to suit your car. Column B increases by 1/32 of an inch each line, and column C is the camber angle measured in degrees, with two benchmark figures highlighted.
Now to build your little tool....
fax
Fax
1983 Porsche 911SC
Old 02-10-2003, 01:13 PM
Guys, Check this out.
Toe Adjust Techniquest
Old 02-10-2003, 01:34 PM
Irrationally exuberant
ChrisBennet's Avatar
Originally posted by jluetjen
Unfortunately doing the cornerweights on a Porsche 911 is a PIA since you need to dis-assemble the rear suspension every time you make an adjustment (another reason to do it before the alignement!).
I have to disagree with you John. Setting the corner weights on the earlier cars is not a PIA - it's a huge PIA.
Setting corner weights on the later 911's ('77 on?) with adjustable spring plates is only a PIA.
-Chris
Old 02-10-2003, 01:36 PM
jluetjen's Avatar
Woa! - Rebirth of a thread that wouldn't die. I wasn't sure if you were referring to me or not Chris - then I checked back and noticed that I wrote that last October. I thought that this thread looked familiar. Oh well -- it still holds true. And I agree with your inflectional change. If you're doing an alignement, let me know. You can borrow my stuff although my corner weight checker has died. Getting a new one is on my to-do list.
- John
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 02-10-2003, 02:29 PM
