Can i shim my calipers?
So I went out and bought a set of rotors, part corresponding to my car, now when I install and tighten, the inner side of the caliper hits the rotor!!!
Can I shim it so the caliper moves a millimeter or 2?
Old 07-28-2013, 08:42 PM
Send a message via Skype™ to Porboynz
Is that a rear? Install the dust shield, automatic spacer.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 07-28-2013, 11:30 PM
cycling has-been
bkreigsr's Avatar
Yes you can shim - washers will be fine.
I'd leave off the 'rock' shield unless you plan to do a lot of driving in the snow or heavy rain where the danger (?) of a wayward rock will find it way into the assembly and wedge itself between the brake pad and rotor.
If you do go with washers as shims, I would make it part of my routine maintenance to re-torque the caliper bolts everytime the wheels are off.
Bill K
Old 07-29-2013, 06:14 AM
great!!
thank u
Old 07-29-2013, 07:02 AM
Hi Porboynz, its the fronts
Old 07-29-2013, 08:24 AM
KTL KTL is offline
Schleprock
KTL's Avatar
What year is your car? Are you absolutely sure you got the right rotors? If you got Carrera rotors (24mm thick) vs. SC rotors (20mm thick), that would explain the clearance problem.
Dust shield does not shim the caliper in front because the shield is screwed to the strut knuckle and has a cutout for the caliper to clear it.
FYI tech info. i've found says caliper center vs. rotor center should be no more than 0.020" (0.5m) Pro-System, Inc.
Kevin L
'86 Carrera "Larry"
Old 07-29-2013, 09:08 AM
I have a 1984 Carrera Coupe. The part I used is Sebro 205197 Vented.
Old 07-29-2013, 05:07 PM
theclaw's Avatar
Weird, i have an '84 and installed some Zimmerman's from our host this spring. No issues.
'84 Carrera (recently sold )
'67 MB 250SL
A few Italian motorcycles
......and a minivan for the crew
Old 07-29-2013, 07:47 PM
Did you compare your new rotor with the old one?
Are you still using the same hubs?
Old 07-29-2013, 09:12 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Agreed i'd compare an old rotor with the new one. Maybe the wrong rotor was put in the box. 205197 is indeed the right part number for your '84 Carrera
Kevin L
'86 Carrera "Larry"
Old 07-30-2013, 07:30 AM
Deadeye's Avatar
What Kevin said. I received some brake pads once that were mislabeled on the box. Quality control is not what it used to be.
Old 07-31-2013, 08:07 AM
