front AC condenser motor question
Does anyone know the run current and air flow for original front AC condenser motor. Are there better motors to compare to, such as foot-well blower motor, that will fit?
Will Hurricane motor meant for evaporator fit? What are their run current and airflow values?
I want to improve airflow to serpentine condenser in front of my 82 911SC.
Thank you, Algernon
Old 08-09-2013, 11:06 AM
Go-Kart Mozart
JAR0023's Avatar
Thank you, Algernon
Search under my name. This has been discussed recently. I measured last year and posted findings. 350ish CFM. You should have a fuse on the feed for the condenser blower. Porsche didn't start with one but they added it later. IIRC the harness from Porsche comes with a 7.5 amp fuse. I have a 10 amp fuse now because the 7.5 would blow when the motor spiked starting up.
Footwell blower motor will bolt right but you will have to change one of the connectors from male to female spade or female to male. Can't remember but it's obvious enough when you have it apart. Footwell motor is significantly faster and louder. More that a few here have done this mod.
I doubt the Hurricane motor will work in that location but I've never had one in my hand. There is one old thread on here where another user cut into the blower housing and used a completely non-Porsche motor.
If you are looking to add airflow I think you best option is to try the footwell blower motor. It's basically a straight drop in and does provide more airflow without have to hack anything up. Easily reversible if you don't like it. Used footwell blowers can be found for cheap if you are patient. -J
86 Carrera
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken
Old 08-09-2013, 11:41 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
AC Front condenser motor current
Thank you, Algernon
I measured this on our '86.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 08-09-2013, 05:34 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Any reason to show off the Fluke.
1981 911SC Targa
Old 08-09-2013, 07:50 PM
Yes, if it works it's a Fluke.
Old 08-13-2013, 05:52 AM
