-   -   What is the fastest drop Engine time did you guys have? (http://forums.pelicanparts.com/porsche-911-technical-forum/764914-what-fastest-drop-engine-time-did-you-guys-have.html)
Chuck.H 08-08-2013 01:07 PM
Remove the axles and then the four engine/trans mounting bolts - the weight of the motor will disconnect most other fuel/electrical/vacuum lines on the way down.
Seriously though, this is a job I tend NOT to rush - I probably take a good 5 hours to get the engine on the ground, working slowly to avoid missing anything (like that pesky front of the engine EFI connector).
HTH,
Chuck.H
'89 TurboLookTarga, 361k miles
dtw 08-08-2013 01:14 PM
Tim Walsh and I once took one from in-car and running, down to the crankshaft, in 4 hours flat. This was with hand tools and no engine stand. If memory serves, we took the motor apart on the tailgate of his pickup truck.
kodioneill 08-08-2013 01:25 PM
Try a 77 Turbo w/ac and see how long it takes. There's to many variations but a good normal would be 1.75-2.25 hours.
fred cook 08-08-2013 01:27 PM
911 Engine drop time
Usually takes me about 2 hrs, half on top, half underneath. Installation is about the same, maybe a tad longer. That is on an SC engine w/CIS injection. Also, I'm not trying to beat the clock, just working at a steady pace.
1-ev.com 08-08-2013 01:56 PM
What do you think guys?
#1 leave engine and jack-up the car would be faster?
http://forums.pelicanparts.com/porsche-911-technical-forum/431138-having-never-dropped-911-engine-2.html#post4197530
#2 or Dropping Engine is faster?
http://forums.pelicanparts.com/porsche-911-technical-forum/431138-having-never-dropped-911-engine-2.html#post4195317
Thank you,
McLovin 08-08-2013 03:11 PM
I've done it in 2 hours on my SC.
But that's (1) leaving the gearbox in place, and (2) I had only reinstalled it a few days before, so everything was spotless, no frozen bolts or surprises, etc.
fred cook 08-08-2013 03:44 PM
Engine drop
Originally Posted by 1-ev.com (Post 7591666)
I jack the car up a bit, take everything loose, support the engine on my ATV jack, remove the 4 motor mount bolts, lower the engine and then finish jacking up the car. Pull the engine/tranny out and then lower the car to a safer height. That way I don't have to be underneath while it is waaaaay up in the air!
1-ev.com 08-08-2013 04:04 PM
how long it takes?
SteamWolf 08-08-2013 04:21 PM
Yet to do it on the 911, but need to in the next few weeks to do the clutch.
My beetle I could do it in 20 minutes, only hampered by the difficulty in balancing it on the jack.
My Chrysler (Mitsubishi) '77 LB Lancer rally car I got it down to 15 minutes. The exhaust manifold was usually still too hot to touch when the engine was on the floor.
The old XF Falcons I could remove the engine, replace the sump and rocker cover gaskets, rear main seal and front seal, and have it back in the car in less than an hour. But when I was in the trade I used to do at least three a week.
fred cook 08-08-2013 04:21 PM
About 2 hrs.
how long it takes?<br>
<br>
<div class="pre-quote">
Quote de <strong>fred cook</strong>
</div>
<div class="post-quote">
<div style="font-style:italic">I jack the car up a bit, take everything loose, support the engine on my ATV jack, remove the 4 motor mount bolts, lower the engine and then finish jacking up the car. Pull the engine/tranny out and then lower the car to a safer height. That way I don't have to be underneath while it is waaaaay up in the air!</div>
</div>
1-ev.com 08-08-2013 04:29 PM
I think Fred's method looks like the safest to me, as you do not have to balance Motor/tranny on single point of the jack, hi on the air...
this is just my opinion, hey guys please correct me if I am wrong...
1-ev.com 08-08-2013 04:33 PM
Sorry, I should explained my intend in the first post.
What I am trying to establish here is the safest-fastest way to remove Engine or Engine/tranny together method...
You all guys awesome!!! LOT of experience...
Brian 162 08-08-2013 05:33 PM
http://forums.pelicanparts.com/uploa...1376008253.jpg
http://forums.pelicanparts.com/uploa...1376008266.jpg
http://forums.pelicanparts.com/uploa...1376008279.jpg
The first time I did it was 2 hours but I took my time. The second time with a hoist it took an hour.
Jerome74911S 08-08-2013 06:03 PM
I've had mine out a couple of times. First time took a week, the second time about four days. So, that's my record so far. Getting it back into the car was harder.
1-ev.com 08-08-2013 06:04 PM
Brian, nice car :-) and nice work too
yelcab1 08-08-2013 06:08 PM
and I thought 2 hours to drop a G50 3.2L carrera was fast including all the looking for tools time. Sheesh, 22 minutes for a GT3 engine . Takes me that long to change the oil.
1-ev.com 08-08-2013 06:19 PM
do not feel so bad, as people here in Key West FL (keys) say: "what takes average person day to do, we do it in the a week" :D ---- I love Keys... it most southern point of US, tho.. where, friend of mine has a website about it ... Florida Keys Vacations but this for another thread... :rolleyes:
Marc Bixen 08-08-2013 06:24 PM
Originally Posted by Peter Zimmermann (Post 7591357)
I bet my guys, at my shop back when I was much younger, that I could get the engine out of a, I think, '71T, in 17 minutes. It took me 21 - had trouble with the upper starter bolt (trans remained in the car). Time started with the car on the hoist, toolbox in place, but no tools out of the box. Time stopped with the engine on the floor jack, and pulled out from under the rear of the car. Also included oil removal.
Pete, I remember that story. Didn't you have to buy everyone lunch or something? Still was impressive. Oh to be young again.:cool:
al lkosmal 08-08-2013 06:26 PM
2 hours to drop..............but it always takes me twice that long to put it back in.
regards,
Al
1-ev.com 08-08-2013 06:30 PM
I think i need to start another thread on put engine back fastest time :D
regards,
Al
