idle screw does not change carb air flow
I was adjusting the carbs for a neighbor.s 914-6 and had 2 problems:
1. Spit back which might be ignition timing, or carb wearing out.
2. Cyl number 2 mixture screw (one with the spring) does not affect the air flow meter set on top of the carb throat at all, all the way in or all the way out does not change a thing.
Spit back I think I can deal with. But the non adjustable air flow stumped me.
What are the causes?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 08-09-2013, 07:51 AM
Senior Member
Jdub's Avatar
Coming at this from BritBike experience with Amals, so YMMV...
First, ensure the meter is well plugged in (so to speak) and has no issue itself that might be causing the non-reading. For example, swapping with another carb to ensure it is reading at all. Seems like a classic case of plugged air passage preventing air from metering into the idle mix (assuming this is what you are reading/setting).
From here I can tell you of the E-string, the syringe with the carb cleaner, the use of the electrosonic cleaning to remove deposits, etc. Many ways to skin a cat. But I must say a thorough cleansing using a quality injector cleaner (SeaFoam? Techron?) may be a good way to start on this.
'78 Targa in Minerva Blue
Old 08-09-2013, 08:05 AM
LJ851's Avatar
No fuel screw on a carb will affect air flow.
What kind of carbs are you working on? If the throttle shaft is one piece per carb, the only way to adjust separate cyl air flow is with air bleeds on the side of the carb (if it has them)
Old 08-09-2013, 08:06 AM
Quantum Mechanic
mpetry's Avatar
Send a message via Yahoo to mpetry Send a message via Skype™ to mpetry
idle jet on that cylinder is clogged ? The idle jet is the smallest orifice in the carb so that's where any dirt or crud will end up. Just pull the idle jet and blow it out.
Mark Petry
Bainbridge Island, WA
81 SC
Old 08-09-2013, 08:15 AM
1. The meter is good and is well plugged in.
2. The carbs are 2 triple webers on the 914-6
3. The same adjustment on the other 5 screws affect the amount of air flow sucked into the carbs, except for number 2
4. Idle jet was pulled and cleaned out with no effects.
5. The air balance screw also has no effects
Old 08-09-2013, 10:53 AM
if the idle is too low, you won't get much response from anything. try it at 1000. the mixture screw should slightly lower, raise and lower the idle as you go from too lean to just right to too rich respectively. so that cylinder may have issues, an intake leak, fouled plug, a plugged idle jet or idle circuit. the balance screws with the 8mm locknut are used to match the airflow as well as possible between cylinders. i start with them closed, balance both carbs close as possible with the speed screw on the ends, with one vertical linkage rod disconnected. then even things out with the balance screws, and then the mixture screws.
206 637 4071
Old 08-09-2013, 11:25 AM
ASE Master Tech - 35 yrs
larrym's Avatar
common problem - remove all the idle screws and "blast" the ports with NOT MORE THAN 15 psi air pressure
- usually cleans 'em out - if not - rebuild 'em
high psi blast will collapse your floats
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 08-10-2013, 09:26 AM
