Banned
Send a message via AIM to prebordao Send a message via Yahoo to prebordao Send a message via Skype™ to prebordao
Continuous popping while idling - lean ? rich ?
I'm having trouble adjusting the mix / pressures:
Latest symptom: while idling and stopped there's a continuous popping from the exhaust... Indicates rich or lean condition ?
Car was not fully warmed yet.
Old 08-23-2013, 12:33 PM
kodioneill's Avatar
Year/model/miles?
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 08-23-2013, 12:51 PM
Banned
1974/S/many
Old 08-23-2013, 01:02 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Is it a popping or "puffing" backfire? I had puffing which was like a mini backfire but not noisy when I had an air leak at the base of one of my intake runners. Happened all the time.
1981 911SC Targa
Old 08-23-2013, 01:04 PM
Banned
It's really a pop-pop-pop similar to the small backfires you can have when your decel valve is not connected and you lift suddenly. But here it was continuous.
Old 08-23-2013, 01:11 PM
Bob Kontak's Avatar
Before I start rambling, did this symptom start after you made some adjustments to pressure and mixture?
1981 911SC Targa
Old 08-23-2013, 02:05 PM
Banned
Yes, after.
But now I know its rich. The wur heating element isnt working so it takes a lot of time to reach oper temperature, so mix remains too rich too long.
Back to the gauges again.
Old 08-23-2013, 02:26 PM
Bob Kontak's Avatar
Try a hair dryer on it to warm it up quicker. just a thought.
1981 911SC Targa
Old 08-23-2013, 02:38 PM
docrodg's Avatar
Double check timing too. A retarded timing can cause a small amount of the pop as well but be hard to detect at high rpm. Reason is fuel burn not complete when exhaust opens giving a pop or huff.
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 08-23-2013, 03:12 PM
Banned
I have the grandaddy of WURs - the 001
I just opened it and it's a bit different inside from the newer ones.
Later I'll post pics and a probable explanation.
This one has an additional resistance inside that seems to cut power to the element when it heats...
From a german Bosch document I get this description:
einsteckbarer elektrischer Anschluss aus kunststoff mit Zusatzwiderstand 3 ohm
Google translates it as:
insertable plastic electrical connector with additional resistance 3 ohm
Any better translation out there ?
Luckily, the heating element tests ok with the multimeter.
Old 08-23-2013, 03:33 PM
Can you post photos of the -001 wur internals and describe how you disassembled (and presumably will reassemble) it? My -001 works, but the warm control pressure is a bit low. Have thought about opening it up to see if a general cleaning might help. And maybe there's some way to make modest adjustments to the WCP.
--Richard
1965 356 SC Coupe
Old 08-24-2013, 05:04 AM
Banned
I just opened a new thread for the disassembly.
They're fully adjustable for warm and cold.
Warm - screw on bottom
Cold - pin
Old 08-24-2013, 06:03 AM
