Window rattle, important part?
My new to me 86 has a window or door rattle. I took the door panel off and when shaking it does not rattle. I did find this in the bottom of the door and think it may be important, but can't find out what it is. What does it do, can it be replaced, help.
Member 911 Anonymous
Oh my, that is off of your window regulator coil/spring, without that you will most likely burn out your motor.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Go-Kart Mozart
Yep. Our host sells an improved replacement IIRC.
There is an annoying rattle in both sides of my '86. Happens only when my windows are somewhere between full up and full down. It's an irritating jingling sound. I found the fix after I had been into and buttoned up my doors twice for other things and I've been simply too lazy to tear back into the doors. Ends of the regulator has plastic wheels that roll in a track just below window glass. Some folks go so far as to squeeze the channels tighter and others just apply heavy grease. -J
86 Carrera Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken |
You have the dreaded window regulator pivot pin failure. There are aftermarket replacement parts available. Beware, there are four different versions depending on what side the window is on and some size variations. Here's an old post with some good links in it.
Window Regulator EDIT: here's the parts page for the pivots http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_INTpnl_pg3.htm#item10
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa Last edited by uwanna; 08-22-2013 at 06:47 PM.. |
Obsessed
mine were rattling from the door handle rods having had their little rubber isolators come loose (among other things).
'73 Mercedes 450 SL '75 911 Targa (long gone, sniff..) http://1975porschetargarebuild.blogspot.com My Targa Rebuild Blog "Life moves pretty fast, if you don't stop and take a look around once in a while you could miss it!" |
It's the pin that holds the center of the assist spring.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
That is most likely why the window goes up slowly! I guess everything has to come out of the door to fix it. Winter project.
Thanks |
