Fan scrape
87 3.2. Fan once in a while scrapes the housing on the bottom. Done this very seldom since I bought it 3 yrs ago. Then the alternator went bad and I just replaced it with a pp rebuilt. Now the fan scrapes even more. It only does it when you have driven awhile, shut the engine off, wait 5 mins or so and crank it and start. It scrapes for 15 seconds, then stops. Any thoughts on how to fix this. It's the original fan and housing.
Old 08-22-2013, 07:10 PM
Member 911 Anonymous
DRACO A5OG's Avatar
When off the car doesit bind? Which belt are you using and how many shims in and out?
'85 Carrera Targa
PCA/POC
Old 08-22-2013, 07:13 PM
Make sure the fan housing is seated properly. Sometimes its tricky to get it seated just right.
May want to make sure the fan belt is not too tight.
Old 08-22-2013, 07:29 PM
scottb's Avatar
Also, be sure the alternator itself is seated properly in the housing.
1984 Targa
Old 08-22-2013, 07:44 PM
Make sure your fan strap isn't too tight. I do t have the spec in front of me, but IIRC it was quite light.
Ken
1986 930 2016 R1200RS
Old 08-22-2013, 07:57 PM
Did you check to see if the fan housing is cracked? If it is maybe when you tighten down, you may have squeezed it and now its out of round
ken
87 targa
Old 08-22-2013, 08:29 PM
The fan housing mounting strap allen bolt tightening torque is 18 ft lbs per Bentley.
Old 08-22-2013, 08:31 PM
A few tens of thousands of miles ago mine would scrape where I had a bubble in the magnesium housing - took it apart and sanded the bubble down and it's been all good since.
Chuck.H
'89 TurboLookTarga, 362k miles
Old 08-23-2013, 06:20 AM
Thanks guys
I'm using a porsche belt with 3 shims inside and outside
Pretty sure I put the alt into the housing ok
Might have the strap bolt over tight or the housing is out of round?
I'll try to move one shim to the outside on the belt and do 18 ft lbs on the strap
Thanks all
Old 08-23-2013, 04:53 PM
Laneco's Avatar
Take the belt off and make sure the alternator is secure on the mount. If the bolts securing the alternator to the assembly are loose, it will rub. Next, make sure the alternator itself does not have play in the shaft.
If none of the above suggestions help (not just mine - the others are excellent points) then you may have to just take it apart and examine it. These housings can crack and it does change where the fan and alternator sit in relation to the lower part of the housing.
angela
Hello
Old 08-23-2013, 05:24 PM
Agreed. I'm going to pull it out and check things carefully. Including checking cracks and out of round.
Old 08-23-2013, 07:03 PM
Cattler's Avatar
Porsche Crest
+1 on your last post--great plan to check for cracks and out of round. Also look for scrapes in the inside of the fan housing, especially where you think its rubbing. A failure could be catastrophic.
1987 911 Carrera Cabriolet (sold)
2009 Prius (daily driver--keeps me sane)
2011 Mercedes GLK350 (wife's car)
2002 Volkswagen Beetle Turbo S (son's car--keeps wife sane)
Old 08-23-2013, 07:25 PM
The Bavarian
After cleaning up my fan and housing and re-installing everything, the fan touched the housing at the lower part. When running the engine, it was clearly audible. I dis-assembled it again but couldn't find anything. Same thing after re-assembly. Then I loosened the belt by putting one more shim on the inside of the pulley and the interference was gone.
- Manfred
Old 08-23-2013, 10:38 PM
Who would think one shim would do the trick! I'm trying that first for sure. If not, then it's all comes apart for crack and roundness.
Old 08-24-2013, 08:15 AM
Walt Fricke's Avatar
The cracks I think you will look for, if you have to do that, are probably in one or more of the "arms" which connect the alternator mounting part in the middle out to the circumferential housing of the whole assembly.
Old 08-24-2013, 11:24 AM
Ok moved one shims inside and re tightened the strap bolt to 18 ft lbs. will try it tonight. Too hot now in Dallas today. Will let you know
Old 08-25-2013, 08:08 AM
redstrosekNic's Avatar
18 ft/lbs is too tight! As seen on Pelican, the spec is around 72 in/lbs. 18 ft/lbs will most likely distort the fan housing.
Dustin
Old 08-25-2013, 09:21 AM
Bentleys shows the Allen strap bolt at 18 ft lbs. so which one is correct?
Old 08-25-2013, 09:30 AM
6 cylinder symphony
Yer worrin' too much. Get a short wrench and snug it down tight. It'll be fine.
'84 3.2 Targa
'89 964 Coupe
"What do you mean NEXT project?" - my wife
Old 08-25-2013, 10:35 AM
thumbdoctor's Avatar
Seat the alternator without the front fiberglass cone first using the 6 nuts. Once its seated, remove the nuts and re-install the cone.
Old 08-25-2013, 06:14 PM
