Problem with reverse
The gearbox on my 930 has for some time been difficult on the reverse shift. Now it is almost impossible to get in reverse. It feels like the shifter is hitting something solid, and it will just not move into gear. Maybe its imagination, but it shifts better when warm.
The car is an '80 with 60K miles. Any ideas will be greately appreciated.
Arnljot 1980 930 GT35R, TurboKraft IC, 965 P&C, 964 Cams, Tial WG, ported heads, BLWUR, RarlyL8 hdrs&mfflr, Zeitronix logger & wideband 1989 928GT 1972 BMW 3.0S |
Hello, I would first try to adjust, there is a good tech article here that tells you how to tweak things up a bit, inspect for any worn or binding parts within the shift linkage.
check the simple things first if you can't resolve this by adjusting or replacing a few bushings, then look into clutch/ cable/ synros etc.... good luck, Peter |
undervalued member
my sc was very difficult to shift into rever as well, a mechanic recommended i shift into 2nd then go to reverse. it worked great. that is assuming that you bushings and ajustment are good.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
I fixed it. It was not at all as serious as I thought at first.
I opened the access panel behind the front seats to see if it was possible to adjust the coupling. It turned out to be a loose set screw in the shift rod coupling. Now its smooth as a knife through warm butter. ![]() Thanks for input.
Thread Tools | |
Rate This Thread | |
