Late 80's 22mm front sway bar question
Does anyone know if the 22mm late 80's "under the car" front sway bar and its 4 correct bushings fit correctly and directly into the pre-existing welded mounts on the control arm and the center mounts to an 1981 911 SC?
Thanks for any info |
I'm pretty sure they do. I just picked one up for my '76 and with the 22mm bushings it should fit.
Works great! Installed one on my '80SC, no problem.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
Absolutely. Perfect fit.
BUT- I wouldn't do it without the corresponding larger rear sway bar too. 81 SC uses 20/18 front/rear sway bars The Carrera bars are 22/21 If you change just the front bar you'll end up with a 22/18 combo.
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
I agree, I did install the 21mm rear as well.
Awesome, thanks guys!
Love your sig quote!!!
How about earlier in the 74-77 cars??
79 SC unmolested 75 911 backdated RSR widebody 71 911T having fun skinny 63 356 outlaw frustrating purists 25 GTS |
I've got the stock front and rear bars from my 1986 930 I'd let go cheap. I know the 86 and up bars are larger the other years but am not home to say exactly what they are. Look it up and PM away if interested.
