R22tech's Avatar
DME timing adjustment screw......what do the numbers mean?
While checking if I have the original chip in my DME, I noticed an adjustment screw with like (7) numbers on it. What is this adjustment? What can it do for my stock 3.2 as far as idle is concerned( mine idles a little low IMO).
85 Carrera Targa (sold!)
03 Dodge Ram 1500 HEMI
Old 08-10-2002, 08:54 AM
R22tech's Avatar
BTW: mine is set at the (0) position as it stands. I can adjust from 0-7 by rotating the screw, but I don't want to change anything until I know what I'm doing.
Old 08-10-2002, 08:55 AM
Early_S_Man's Avatar
http://forums.pelicanparts.com/search.php?action=showresults&searchid=106192&sortby=lastpost&sortorder=descending
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-10-2002, 09:58 AM
R22tech's Avatar
So Warren, are any of these my DME? Or, do I assume I should just leave this is adjustment in the stock http://944dme.tripod.com/switch.htmposition (0)? Anyone ever experiment with this adjustment?http://944dme.tripod.com/switch.htm
Old 08-10-2002, 11:37 AM
R22tech's Avatar
Using the table on the U.S. DME: what would be the result of setting it to position (4), which is a (0) % change in fuel mixture and a -4.15 % change in ignition timing?
Old 08-10-2002, 11:42 AM
R22tech's Avatar
Old 08-10-2002, 11:50 AM
