RazorRacer's Avatar
Cool Problem Solved - guess what it was...
O.K. this problem that I have been chasing for the last 6 months or so is solved. If you are interested, let's play a game. You guess what it was and I tell you if you are warm or cold. The first person to guess the complete answer gets a $50 gift certificate to Pelican Parts.
Here are the clues:
Starts great hot or cold.
Runs good until warm then there is hesitation at constant speed.
Runs great above 5800 rpm if hot or cold.
Big clue: previous owner only half way fixed the problem.
Here are the things I tried to fix it, but they didn't work:
Replaced fuel filter.
Replaced fuel pump with internal check valve.
Sprayed carb. cleaner to check for vacuum leaks - NO LEAKS.
Set timing.
Checked electrical distributor cap - fine.
Checked fuel distributor for a fouled plunger, but failed in my efforts, but that wasn't the problem.
I could give the answer here, but if you are interested, let's have some fun.
Bottom line: problem solved and I am
Stopped racing and became a drummer
Old 08-10-2002, 04:41 PM
pwd72s's Avatar
The answer is too easy! You gave it away in your signature..
It's a Targa. They ALL do that. Apologies...I really don't have a clue. But how many times have we all heard those four words from a dealership service manager? (An oxymoron in it's own right.."service manager") THEY ALL DO THAT???? Like by saying this, "THAT" is suddenly okay?
Old 08-10-2002, 04:48 PM
avi8torny's Avatar
Send a message via AIM to avi8torny
fix
temp sensor or flywheel position sensor...that's my guess.
12' GT3
18’ 991S
Buy them, sell them
Adam's Avatar
Porsche Crest
Ok..
It's gotta be related to the injectors, right? Needless to say, they'd get new seals if you replaced them. Possibly the Beru connectors/plug extensions also. They were a major fault on my 2.7, causing it to run on 4 glorious cylinders!
1931 Oakland Eight Special Saloon
1985 BMW E28 525e (Euro 528e)
1989 911 Carrera Sport 3.2 G50 Cabriolet
Old 08-10-2002, 05:02 PM
RazorRacer's Avatar
Adam: injector - cold
avi8: flywheel positioner - cold. Temp sensor - cold.
72s: WTF?
I'll be checking reply's tonight and tomorrow morning, but I have a race all day tomorrow. Then back at it again Sunday night and the rest of the week.
Is this fun?
Old 08-10-2002, 05:25 PM
adamnitti's Avatar
Send a message via AIM to adamnitti
razorracer, i don't have a clue, but i'm just glad it's fixed! congrats!
Adam Nitti
www.adamnitti.com
...In search of the next 911...
Old 08-10-2002, 05:43 PM
RazorRacer's Avatar
Thank you Adam. This is a high moment in my P-car life.
Old 08-10-2002, 05:44 PM
Bill Douglas's Avatar
Razor, I'm pleased it fixed. This has been bugging me too being an SC man.
Was it due to the charcole filter being removed and a leak getting into the airbox causing a lean mixture?
Bill '79SC
Old 08-10-2002, 05:49 PM
RazorRacer's Avatar
Thanks surfer dog. My board has been neglected in my P-car efforts. Not much wave here in Houston.
Sorry to say that the charcol filter is cold.
Man, I'd love to try some down under waves.
Old 08-10-2002, 05:56 PM
Kevin Stewart's Avatar
Lets see how about the cdi connection or box, Kevin
Old 08-10-2002, 06:11 PM
joeycatt's Avatar
Razor!
Time for mucho joy! I'm waiting to hear what it was....(obviously none of the things we suggested)
The excitement builds....
Old 08-10-2002, 06:14 PM
A Quiet Boom's Avatar
The vacuum advance unit on the distributer was bad.
Specifically the spring in the vacuum advance was allowing too much timing to early in the rpm range, once the engine reaches 5800 it's close to the point where total timing should be in effect and therefore the problem "goes away" since the engine needs that much advance at those rpms.
Possibility number 2 would be a no-functioning mechanical advance which wouldn't give the engine enough advance under load when the vacuum signal is weak and therefore the vacuum advance is barely functioning.
Old 08-10-2002, 06:19 PM
Super Jenius
Overpaid Slacker's Avatar
Send a message via AIM to Overpaid Slacker
Razor --
The muffler bearings?
There's nothing like putting a stake through the heart of a tenacious automotive problem -- congrats!
- JP
2003 SuperCharged Frontier ../.. 1979 930 ../.. 1989 BMW 325iX ../.. 1988 BMW M5 ../.. 1973 BMW 2002 ../..1969 Alfa Boattail Spyder ../.. 1961 Morris Mini Cooper ../..2002 Aprilia RSV Mille ../.. 1985 Moto Guzzi LMIII cafe ../.. 2005 Kawasaki Brute Force 750
Old 08-10-2002, 06:21 PM
Warren Hall Student
Bobboloo's Avatar
WUR?
Bobby
Old 08-10-2002, 06:23 PM
RazorRacer's Avatar
joeycat: thanks for all of your help. You kept me going throught the rough times.
boom: you are very warm with #1 and I think you have answered the problem. It's not exactly what I was expecting for an answer, but you have the right idea. Can you please elaborate for us who are not a knowing as you?
Slacker: WTF? muffler bearings?
bob: WUR was a first check. Took the vacuum line off and expected the problem to go away, but it didn't. WUR: cold.
Old 08-10-2002, 06:45 PM
Ha you mean tha cat converter was pluged, Kevin
Old 08-10-2002, 06:48 PM
RazorRacer's Avatar
Kevin: cat converter was not plugged. Should have mentioned that as one of the things checked, but forgot about it.
Boom: you have the answer, but please elaborate on how you knew this. Many before you have tried, but you hit the nail on the head. I want to share my personal experience how I found it, but am waiting to hear more from you.
Old 08-10-2002, 06:53 PM
Super Jenius
Razor -
A joke. I had no clue.
PO halfway fixed it?
JP
Old 08-10-2002, 06:57 PM
i believe boom has the answer also, as either the advance was rusted or the wire to the distributor was bad, if it is the answers it was booms, yo da man boom, , Kevin,,,, i think i am spending to much time on this bbs, i need to get a life and stop eating sleeping, thinking Porsches all day, well maybe not when I sleep,
Old 08-10-2002, 07:03 PM
rstoll's Avatar
Fuel pump relay socket.
Robert Stoll
83 911 SC
83 944
Old 08-10-2002, 07:04 PM
