turn signals only work with hazards on but hazards dont work
When my hazard button is off my turn signal switch doesnt work
With hazards on the hazards do not flash but there is a constant buzzing noise until i use the left or right turn signal which then functions as it should The hazards do not work at all and the only way to make turn signals work is to turn hazards on and signal left or right Also the highbeams turn off the headlights and do not work Any ideas on what is going on? Its always been like this i dont know what the wiring looks like or what relays are installed. It has h4 headlights though |
Problem Fixed
wiggled some wires and swapped some fuses(corrosion) |
