Bench-testing a 915
Is there a way to confirm that a 915 will shift properly when installed in a car, on the bench?
Tru6 Restoration & Design |
I have wondered the same thing short of building a stand with a seat and clutch assembly.
John- 78 Slick Top 930 "Illegitimi non carborundum" |
Test shift after rebuild........
Shaun, When I did my 915 rebuild many years ago and 'test shifted' the 915 transmission on the bench (less transmission fluid). But be aware that '1st gear' would be on the opposite side (5th gear) and everything is reverse location. I had a collar with handle placed on the shift lever to facilitate the shifting. With this simple method, I was able to get into different gears (1,2,3,4,5, & R). HTH. Tony |
You cannot simulate loads during a bench test; all you can do is to select gears.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
LOL! You beat me to it, I was going to write the exact same thing.
Keep the Shiny Side UP! Pete Z. |
Thank you Gentlemen, appreciate it.
i would just bench test it by trying every gear and make sure each one turns freely. thats really all you can do
82 SC , 72 914 |
