CharlieWest's Avatar
What is this 911SC part?
I opened up the compartment that holds the shifter linkage and found this "part" laying at the bottom. Does anyone know what it is? Cause for concern?
Old 09-20-2013, 01:52 PM
poorsha's Avatar
If my failing memory is correct it is one part (top or bottom) of a wire connector/joiner.
78 911SC sunroof Coupe (SOLD)
97 328i Convertible
Old 09-20-2013, 02:05 PM
porwolf's Avatar
That is a commom Porsche 2-circuit blade type connector housing. Here is a picture of one in an original 79 SC headlight bucket:
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 09-20-2013, 02:12 PM
Speedometer wires connector........
Charlie,
That plastic connector (T2i) is used to connect the speedometer wires from engine to chassis side located in the tunnel (see circuit #70). Check the tunnel area where you found it and you'll see the green & brown wires (from transmission) and 2 brown/red wires going to the dash (front).
Tony
Old 09-20-2013, 02:29 PM
poorsha's Avatar
Brain still works
97 328i Convertible
Old 09-20-2013, 02:31 PM
