Flat Six Cad File
Any CAD guys out there, that have purchased this CAD file and can comment on the quality of the data. From the images it looks reasonable.
3d air cooled flat six engine
Outlaw .... by definition ..... does not follow rules well www.FloydDesign.ca https://www.youtube.com/watch?v=sV5aIALWlG8 |
Guest
Posts: n/a
Tom,
I think it's a lot of money for what even the seller say that "It is based loosely on the earlier 3.2 liter". Why would you like to buy it? Otto |
Hi, Otto
Just thinking about a couple of winter design projects, in and around the engine nice to have some surrounding environment cad. I do have access to a FARO arm to capture some data but this file might shorten time involved. Cheers, Tom
Chain fence eating turbo
Nothing to add but man that looks cool.
That's a great deal but your looking at the 3d max file rendered not the cad
File. |
Tom, I guess it depends on what are you looking to do this model. According to the description the geometry is polygonal. Thus, I assume this means the data is not parametric or boundary rep, and therefore I don't know how accurate it is if you wanted to take measurements. Do you have a seat of the software to modify it or manipulate it? Furthermore, the model looks incomplete, as I'm not seeing any of the pistons or valve train.
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus Last edited by wrxnofx; 09-21-2013 at 06:19 PM.. |
Guest
Posts: n/a
Tom,
I think as a source of inspiration it would be great. BTW Nice beach chair on your site! Otto |
Thanks Otto
WRXNOFX It has been quite a few years (10+) since I have work with cad on a daily basis. I have previously use Cadkey, and limited experience with UG, and Ideas. I have access to Solidworks now, to do a few home and P-car projects. I am thinking of buying the dxf file and import it to SW. I don't need the engine internals or the parametric features, dumb solid would do. I can check dimensional accuracy with a FARO arm, if required. I do like SW's parametric modeling compared to my old Cadkey software. When all else fails, I still have my drafting board Cheers guys, thanks for the feedback
Hi Tom,
I have this file. It is reasonably good. I checked a few critical dimensions and there is a slight error in all of them. For example the cylinder centerline spacing is off by ~1mm, The engine carrier mount holes are off by ~1mm in various dimensions. The DXF file has each of the main components on different layers - so whoever modeled it knew that they were doing. Let me know if you have any other questions, Richard.
RSR Replica - http://forums.pelicanparts.com/porsche-911-technical-forum/472762-rsr-update.html 930 Cab - ex-IA car, 3.4L, 1.2 bar, G50 996 Turbo - X50. |
Matt
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
