This can't be right- front end height adjustment
I've been doing a good bit of searching, and think my issue might be with re-indexing my torsion bar adjustment levers.
From what I understand, the levers are currently maxed at their lowest setting. However, I have a significant gap between the tire and both front fenders.
And here are the passenger's and driver's side torsion bar adjustment levers. From my understanding, this position is fully 'lowered':
No matter which direction I turn the adjustment bolt, the levers do no budge. I have soaked them both in PB blaster, and tried gently prying them with a pickle fork and no tension from the bolt. Nada.
Thoughts? Where would I find a spacer puck if the car had one?
Old 09-28-2013, 12:09 PM
Alii&Maui
Jesset100's Avatar
What this is telling me is the front struts are bottoming out against the bumpers. Search "strut bump stop".
1982 SC Coupe
SCWDP#0087
KCSSL#0082
Old 09-28-2013, 01:06 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Are you absolutely sure that is the direction for lowering it? Seems to me (and I am ignorant on this issue) that if you add tension to the spring the car goes up.
Back them off a quarter inch and drive around the block.
Suspension settling is required when you make these adjustments.
Puck is on top of the shocks. About a half inch thick if your car has them. 3" diameter or so.
Lots of folks here who know this stuff. You will get an answer.
1981 911SC Targa
Old 09-28-2013, 01:11 PM
RETIRED
Joe Bob's Avatar
Lower ride is best done with corner balancing and alignment.
You can drop the puppy to the floor if you re-index the adjusters. BUT it ride and corner like Bob's truck.......Oi.....
2012 ML350 3.0 Turbo Diesel
Old 09-28-2013, 01:26 PM
Bob Kontak's Avatar
Like that's a bad thing.
1981 911SC Targa
Old 09-28-2013, 01:32 PM
RETIRED
Joe Bob's Avatar
Gud fer throwing bodies out on a corner.....
Old 09-28-2013, 01:34 PM
Northern Motorhead
wildcat077's Avatar
Just support the car under both front torsion tube covers and unscrew your adjustment bolt,then pop off the caps and reinstall them with the threaded part facing down.Afterwards screw your adjusters back in and it should give you more range for your lowering task !
Cheers
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 09-28-2013, 01:41 PM
Thanks all for the replies.
Phil- If it's as simple as just re-indexing the adjustment caps, then that's great. I wanted some positive reassurance before removing the caps, though. It also gave me some time in the afternoon to clean the car for the first time in 6 months. She had quite a nice layer of mold all over the paint from sitting under a tree.
Old 09-28-2013, 02:37 PM
Would this not mean the car's height from the ground would be lower, though?
Not arguing, just wanting to better understand.
Old 09-28-2013, 02:39 PM
Northern Motorhead
wildcat077's Avatar
No because your car is still supported at the torsion tube covers ... all you're doing is reindexing the caps to give you more range.You can reach all that by under the car,just jack it high enough for access and you can do everything with the wheels on .
Cheers
Phil
Cheers
Phil
Old 09-28-2013, 04:11 PM
Sounds great. Any advice for getting the caps off if they're stuck on?
Old 09-28-2013, 07:20 PM
Been doing some more searching and reading. I came across this:
Originally Posted by boyt911sc View Post
Buck,
Tony
It appears that the adjustment bolt is meant to run through the arm of the TB cap, and I imagine the turning of the bolt in either direction will cause the cap to 'ride' up and down. If this is the case, should the adjustment bolt be in constant contact with the stop? On my car, the bolts don't even make contact with the stop. If I turn the bolts to run them through, they get extremely tight and don't budge.
I guess I'll have to get the caps off and try to run the bolt through them off the car. I have a sneaking suspicion the caps may need to be re-tapped due to cross-threading.
Old 09-28-2013, 07:57 PM
Under the radar
Trackrash's Avatar
What year is your car? Some US models had a spacer (doughnut) to raise the car for bumper regulations around 1976.
Gordon
'71 911 Coupe 3,0L outlawed
Old 09-28-2013, 09:00 PM
Car is a '77. ROW (Japanese, specifically) vehicle.
Old 09-28-2013, 09:02 PM
Under the radar
Trackrash's Avatar
Yes and yes.
To remove the "caps" you need to jack up the car, remove the adjustment bots, then pry off the caps. You can then re-index them on the end of the torsion bars.
While in there it is a good idea to pull out the torsion bars and check to make sure they are not rubbing. This is common on older cars when the front a-arm bushings wear.
Gordon
Old 09-28-2013, 09:14 PM
Remove adjustment bolts, pry off caps, check threading on caps and bolts (see my comment above about cross threading), replace caps on end of TBs with the arm facing downward, screw in bolt until the caps have rotated to the point of positioning the front end at the proper height.
Seems simple enough. Of course, theoretical processes aren't ever as simple as actual processes...
Question: If the adjustment bolt it meant to stay 'stationary' and in constant contact with the stop above the cap, how is it held in place? Is it possible that the cap or TB on my car is seized, not allowing the cap to move?
Old 09-28-2013, 09:51 PM
Under the radar
Trackrash's Avatar
When you jack up the car the tension on the adjustment screw will be released. The end of the screw is not held in place, it is only forced against the upper part of the "bracket" by the cars weight.
Jack up the car and you will notice the tension on the adjustment screw is released.
This should allow you to unscrew the adjusting screw which looks jammed in place now.
Gordon
Old 09-29-2013, 09:21 AM
Bob Kontak's Avatar
It looks like the adjustment bolt hex head on yours is not through the access port like in Tony's picture.
Something is wrong. Jammed like trackrash says, maybe? The torsion bar can't spin with the adjustment bolt head hitting the bottom of the bracket rather than going through the hole.
Is that what I am seeing? Maybe the head of the bolt can't bee seen because of the picture angle?
1981 911SC Targa
Old 09-29-2013, 09:49 AM
Bob Kontak's Avatar
Sorry - I did not see this before I posted my comment.
I need to just step away. :-)
Carry on.
1981 911SC Targa
Old 09-29-2013, 09:56 AM
What is the recommended tool/angle/procedure for prying off these TB caps? Mine seem pretty happy sitting where they are, despite soaking in PB Blaster.
Old 09-29-2013, 05:24 PM
