window putty
i had to remove the front quarter window on my targa (78) for some repairs. there was some putty there to stop noise i imagine and it is old and crumbling. is there a prefered product for this ?
thanks
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Go-Kart Mozart
Butyl rope. Butyl tape. 3M will call it Window-Weld. If you can't find a small enough diameter you can simply stretch it. Works great to seal moisture barriers to the inside of the doors. It's cheap enough to buy a roll but if you just need enough for the quarter windows stop by you local auto glass shop. They might sell you just what you need. -J
3M 08620 Window-Weld 1/4" x 15' Round Ribbon Sealer Roll : Amazon.com : Automotive ![]()
86 Carrera Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken |
El Duderino
It's also called dum-dum although I am not sure of the spelling.
thanks guys. apparently from what i read dum dum is no longer produced. i think product above shoukl fit the bill
![]() thanks again
Less brakes, more gas!
Interesting... I was told to use plumbers putty... works fine
![]() ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
i went to the local glss repair shop and he gave me a couple feet of the butyl stuff for nothing .. worked great ...I am sure it will be WAY quieter now ..
![]() Actually the reason i had it apart is i was replacing the drivers side actuator, I had to pull out the regulator slid eon that side anyway so i cleaned and adjusted the whole thing to see if i could make it quiter .. quite a good project .. I have enouggh left over to seal up the window on the other side too if that is all cracking.
Thread Tools | |
Rate This Thread | |
